2001 leveling kit - Ford Powerstroke Diesel Forum
post #1 of 7 Old 01-31-2012, 07:02 AM Thread Starter
deerman14's Avatar
2001 leveling kit
hey guys, I have 01 F350 SRW CCLB 4x4, it is time for tires and I want to level it before I buy tires, is there anything out there that I can just the block the front, or do I have to buy a kit, such as add-a-leaf with trac bar. I would appreciate any input, thanks........
deerman14 is offline
post #2 of 7 Old 01-31-2012, 08:51 AM
I added 2'' on mine, and just used a cheap ol' daystar block. Of course you'll need to 1 up your shocks, but you can also lift by adding a leaf. (daystar 2'' block kit cost $30) did both sides in about 1.5 hours, from tires off the ground, to driving away.
seven_point_three is offline
post #3 of 7 Old 01-31-2012, 01:02 PM Thread Starter
deerman14's Avatar
I didn't think you could do the blocks on the front of a straight axle 4x4?
Please explain.....
post #4 of 7 Old 01-31-2012, 01:10 PM
southern7.3's Avatar
Youre not supposed to use blocks on the front. You also run the risk of getting you rig impounded for crap like that in most states iirc its illegal, and dangerous
Do it right and get a leveling kit. Add a leafs will make your ride a little stiff but it is way better than putting a block in the front
The truck in the sig pic is running 35"s on a 2.5" rough country leveling kit.
Sam
2005 F350 King Ranch CC DRW Insight Leveled 4" MBRP Straight Pipe Tinted
'99 F250 - Sold
'99 Cummins - Sold
southern7.3 is offline
post #5 of 7 Old 01-31-2012, 01:14 PM
from a dealer....
Product Description:
Rough Country Rear Block with U-Bolt Kits -
All kits include 2 cast iron riser blocks, 4 U-bolts, 8 heavy duty flat washers, and 8 hi-nuts. All blocks are tapered in order to improve vehicle driveshaft angles. Do not use blocks on the front axles of vehicles.
This kit fits the 99-09 Ford F250/F350 Pickup 4x4 and delivers a 3" rear lift.
Sam
'99 F250 - Sold
'99 Cummins - Sold
post #6 of 7 Old 01-31-2012, 02:26 PM Thread Starter
deerman14's Avatar
thanks, Southern7.3
post #7 of 7 Old 01-31-2012, 02:45 PM
I used a mini spring pack and got about 2-2.5" leveled in the front, keeps the factory ride quality and no new shocks required. I did add an adjustable aftermarket track bar however some have done without it. Leveled my 350 perfect.
-Dave
2001 F350 ECLB 7.3 Lariat
AFE, 38R, 238/100's, DP live tuned, DI RR, HPX, Procomp 6.5" lift, 35" Xterrains
average is offline
