99 f350 7.3l, motor and trans pulled - Ford Powerstroke Diesel Forum
Old 01-30-2012, 09:46 PM
Hello, I have The motor and trans Pulled out of my 99 f350. Is there anything I should address while I have easy access???? Thanks in advance
Old 01-31-2012, 04:59 AM
Your turbo up pipes are probably leaking and it's way easier to replace while you have it out. Consider the bellowed up pipes from international if you have the cash. Also check the oil pan for rust issues. If its starting to rust just replace it now since you can't do it with it in the truck.
