7.3L block cavitation - Ford Powerstroke Diesel Forum
Old 01-30-2012, 06:32 PM
Question 7.3L block cavitation
Do we as 99-03' PowerStroke owners need to be concerned with block cavitation from the lack of the additive in antifreeze, or is this only for older 7.3L's such as the IDI's, etc?
Old 01-30-2012, 07:45 PM
GAS GAS is offline
Yes we do.
for more information search for coolant flush, there is lots of it on the site.
This is from a Cummins motor if I remember correctly.
Another view in a following post.
Old 01-30-2012, 11:43 PM
from my understanding it's all diesels that have to worry about it.
Old 01-31-2012, 12:14 AM
How long before it causes issues??
I guess there would be multiple factors deciding that though. :/
Old 01-31-2012, 12:21 AM
Ya I think it's more of how it was taken care off. That's why elc is a good choice to help prevent caviatation
Old 01-31-2012, 08:15 AM
OK. Can someone help on where to get started? Do I need to start by testing the radiator fluid with a test strip and see if the fluid needs to be changed? And if it's good, then just put some additive in there? Or do I need to perform a few system flushes?
I bought my truck with 189,000 and I now have almost 220,000 miles on it and I have NO idea about the service history of the coolant.
Thanks
Old 01-31-2012, 08:55 AM
You just sca's up in the coolant. You can test with strips and if you put a coolant bypass filter on it they contain sca cakes in the filter to keep the coolant happy.
Old 01-31-2012, 09:05 AM
Question
"sca's" ???
special coolant additive?
So I know I haven't changed the coolant in almost 30,000 miles. It may have actually been more. Does the coolant need to be changed regardless?
Someone tell me what I need to do. Just buy a good 50/50 blend and add the ELC? Or do they already sell a good premix of coolant that already has the ELC? Would this be the CAT brand?
Old 01-31-2012, 09:30 AM
If you flush the system out to and EC-1 (extended life) rated coolant you don't have to check SCA levels. I went with Catapillar brand EL.
Old 01-31-2012, 09:54 AM
is it true you can't run red elc in an early 99?
