Transfer case questions - Ford Powerstroke Diesel Forum
Old 01-30-2012, 03:15 PM
PMR = JUNK
Got a couple of questions about SD t-cases. First off, what is it called? If i remember right, the manual linkage tcases are NP271, and ESOF is NP273. Is that right? Next, what are the differences between the tcases behind a 4r100 and a zf6? I know the input shaft is different, but is that it? We did a ZF6 swap in my buddies truck and we need to know this stuff so we can finish it up.
Old 01-31-2012, 12:46 PM
PMR = JUNK
Old 02-02-2012, 06:03 AM
My ESOF has 273 wrote on it. I'll have to check my manual shift, but I believe you are right on it too. That is the only difference in the cases. Both will bolt up to either tranny with the input shaft change. I personally went to the manual case with my zf swap just to get rid of all the "e" stuff.
