Looks like alternator but in wrong spot - Ford Powerstroke Diesel Forum
Old 01-29-2012, 10:57 PM
Ok--last post for a while.
Whle replacing the GPR this weekend and then looking around under the truck I cam across something that looks like an alternator but was under the truck on passender side. Had a dodge cumming guy look at it and he had no idea. Resembles an alternator ....Any ideas????
Will take some pics if no one has a clue.
Old 01-30-2012, 05:22 AM
dual alternators on your truck maybe? It's an option, my yellow truck has this... main one is top of motor, to left/driver side in the stock/normal location, and 2nd is mounted on the right/passenger side, low. Pain in the rear to change too... done from below, and thru the wheel well if I recall. This set up takes a diffrent serpintine belt too, so make sure you tell the parts store if you have the dual alt set up.
Old 01-30-2012, 05:53 AM
That's cause it IS an alternator. You have the dual alternator package.
Old 01-30-2012, 07:37 AM
Ok -- now it makes sense why it looks like an alternator. The question is why? Is this a mod or stock.
I just replaced the alternator on the truck a year ago because it was failing to keep the batteries charged -- guess I got lucky that I chose the bad one.
Old 01-30-2012, 10:37 AM
It's stock. Dual alternators were an option on these trucks.
