Used Gauges? - Ford Powerstroke Diesel Forum
Old 01-29-2012, 04:29 PM
Feo Feo is offline
Used Gauges?
Hi, I'm new around here, so I'll start with a dumb question. (Nothin' like starting off on the right foot, huh? )
Will the gauges from a 6.0L Powerstroke (boost, egt, trans temp) work on an '01 7.3L?
Will different sending units/hookups be needed?
Old 01-29-2012, 04:37 PM
assuming you can get the probes out without damage you should be fine just hooking them straight up. I don't see where there would be any difference
Old 01-30-2012, 04:20 AM
Send a message via AIM to rufushusky
Nope should work fine assuming you remove the senders without damaging them.
I had all used gauges on my dodge and they all worked fine.
