Need Assistance!!!
Ive got a 2001 7.3 the pcm went to **** replaced it , injector control module replaced, new injector, new hpop, glow plugs, y pipe, im just getting it all back together and i wana know the proper way to get it started with out f-in it up any help would be great i love workin on them but im not ashamed to admit im still learnin a lot so for the experienced guys can you help????
....... oh and i put the air intake heater delete in not sure wat to do with the wires...
nobody has any idea??
Hope this is not too late
What I did on mine was to refill the HPOP oil reservoir with oil with a bottle with a small tube on it, through the small plug on top. This allows the pump to prime quickly. I also topped off the oil rails in the heads with oil, yours is probably full since you did not have the heads off. It should crank up pretty quick but run rough for a while, until all the air works its way out. As for the wires you need to insulate those and tie them out of the way at a minimum. That delete leaves a code on the computer, not sure if that one posts a CEL or not? There is no way to dummy that out that I know of.
Hope this helps. |
thanks much ill let ya know if i got any problems!!
