Dash lights not working????? - Ford Powerstroke Diesel Forum
Old 01-27-2012, 04:52 PM
My dash lights behind the gauge cluster are not working. I have checked all fuses and all are good. My radio and cigarette lighter and all other lights work. Any ideas? Thanks.
Old 01-27-2012, 05:06 PM
I have had an issue with my dash lights, they would go off whenever i put my window up..... Turns out that the issue was a spider web or something was shorting out a wire. Try sticking your hand up underneath your steering column and moving wires around. Fixed my problem, might be worth a shot.
Old 01-29-2012, 03:33 PM
I checked all wiring under the dash and all seem to be okay. Is there internal bulbs inside of the dash cluster that burn out? Any help appreciated.
Old 01-29-2012, 03:53 PM
Yes, there are bulbs. I think it's 6x 194 type bulbs. All but one of mine was out when I pulled my gauge cluster to fix them. There's a bunch of idiot light bulbs but they are a smaller bulb and I didn't replace any of them.
It's about a 1-2 hour job to pull the cluster, change the bulbs and reinstall. An afternoon well spent for me.
Old 01-29-2012, 06:07 PM
ok thanks. I just realized that the lights behind my a/c control knobs are out also, so im guessing its more than just burnt bulbs?
Old 01-29-2012, 07:59 PM
check fuse 19 under the dash if this is the case u also need a new shifter handle happend to me the gauge cluster would shut down...if its lights to then theres a bigger issue check the plug at the back of the lcuther must of come loose
