Edge Insight CTS vs. transmission temp guage - Ford Powerstroke Diesel Forum
post #1 of 9 Old 01-27-2012, 01:30 PM Thread Starter
My tranny is heating up to warning level on the stock guage (even to the red when towing uphill) so I need to get a way to monitor transmission temperature. I know the Edge Insight will monitor the transmission temp, but since there is no trans probe, I assume it's getting the temp from the OBD port. The traditional analog guage has a probe to install in the transmission. Is one more accurate than the other? I assume the probe is the most accurate, but not sure. Has anyone tried both side by side to compare?
Bottom line is I'm leaning toward the Edge Insight CTS monitor since it seemingly can do so much more than just 3 or 4 pillar-mount guages, so I wanted to know if I can trust the trans temp on the Edge unit.
My plan is to monitor transmission temperatures to make sure it is indeed overheating, then install the 6.0 trans cooler. (I'll probably install the 6.0 cooler either way. It's expensive, so just saving up the money. I know, I know it's cheaper than a transmission rebuild.)
Thanks!!!!
2002 F250 7.3 4x4 CC LB SRW, 4" turbo back exhaust, K&N Intake, Edge juice w/attitude, 05 Front end conversion, 08 tailgate and rear bumper, Torqlift Superhitch Magnum. Future mods: ditch the Edge Juice w/Attitude and replace with Edge Insight monitor (or guages), DP Tuner F5 with custom tunes, John Wood trans.
doonin1 is offline
post #2 of 9 Old 01-30-2012, 08:14 PM Thread Starter
Bump...
Any insight (pun intended) on this issue....
doonin1 is offline
post #3 of 9 Old 01-31-2012, 07:36 PM
Ogre's Avatar
I have the Edge Diesel CTS and you are correct that it's getting the transmission temperature from the OBDII port and the factory installed temp sensor. I don't have a separate gauge other than the one installed in the dash, which I think started on the 2002 models. Last summer while pulling a 30' camper trailer behind my F350 going to the Grand Canyon and southern Utah in temperatures of 100F and higher, I had some issues with my transmission running a little hot due to many steep mountain passes I had to drive through. I did notice that the temperature on the CTS correlated to the gauge in the dash. One time, the gauge in the dash went to the edge of the red zone and the CTS said the temperature was around 250F degrees. I pulled over and let the tranny cool for a while.
I think the CTS temp is accurate, but I'm no expert and didn't have a temp gun to take a reading. What I noticed is that the normal range for the transmission temperature is 100F added to the ambient outside temperature. If its 80F outside, transmission temp runs about 180F (this is only while towing a heavy load like a camper). It runs much cooler when just driving the truck with no load, usually never above 140F.
In my opinion, I like the Edge CTS and you can't beat all the options you have for monitoring your truck's systems. On top of that, I believe it's a pretty good tuner.
I also upgraded my PS cooler, but not with the 6.0 version. I have a pretty good sized one that I relocated in the center of my grill. Can't even tell its there because it is black and nearly invisible against the radiator background. It is about 12 inches square and about 1 to 1.5 inches thick. Huge help in keeping tranny temps down while pulling the camper.
Hope this helps.
Ogre is offline
post #4 of 9 Old 05-20-2016, 07:19 PM
Ty60's Avatar
The edge CTS is also a tuner? I thought it was just a monitor?
2006 6.0 F-250 Lariat CCSB, 160k miles, ARP studs, lost EGR, 205/75 Warren sticks, regulated fuel return, Garrett turbo, FASS, Atlas 40 FICM, SCT Livewire with Innovative and Gearhead tunes.
Ty60 is offline
post #5 of 9 Old 05-20-2016, 07:40 PM
blue99stroker's Avatar
Quoted: 289 Post(s)
If you get the whole package it had tunes. But they are Terrible tunes. They have crappy shifting and high egts.
Most analog gauges last a very long time. Typically the edge monitors last only a few years.
blue99stroker is offline
post #6 of 9 Old 05-20-2016, 08:07 PM
Ogre's Avatar
Going on 6 years, and no issues with mine...
Ogre is offline
post #7 of 9 Old 05-20-2016, 08:09 PM
Quoted: 289 Post(s)
That's pretty lucky but glad it's still working. Everyone I know has theirs last about 3.
post #8 of 9 Old 05-20-2016, 08:20 PM
ZMANN's Avatar
Quoted: 1900 Post(s)
I have never seen anyone report that their Edge insight crapped out
I had version one for a few years and traded it in working fine for a CTS 4 years ago never a hiccup from the CTS
I will be upgrading to a CTS2 and will sell my CTS without reservation fully expecting to last many more years
We Miss you Ronnie
6.0 flush pdf
ZMANN is offline
post #9 of 9 Old 05-20-2016, 08:36 PM
Gman239's Avatar
Quoted: 111 Post(s)
I have an autometer Trans temp gauge and the cts2. They are always within about 3-5 degrees of each other.
Autometer running from the port on the Trans(this is post cooler I believe).
Cts2 from the obd port obviously.
Zf6 swapped with southbend.
S&B intake.
Riffraff cac boots.
Cfm Intake spider.
Riffraff plenum inserts.
Ccv mod.
RR OCR.
38R.
Beans diesel sump.
4'' turbo back.
MB hpop
DD regulated return w/bowl delete.
Corey's hpop and hpx lines.
Php hydra
Edge cts insight.
Autometer boost,trans, and EGT.
Isspro hpop and coolant temp.
Sinister diesel coolant filter.
OUO trac bars.
8" on 37's
Gman239 is offline
Tags
edge insight , transmission
