K&N Filter Swap?
Hello everyone.
I have searched many of the forums with "KN" and "K&N" and did not find much on the actual filters. I understand the issues that have come up for certain trucks and dusting the engine. For this reason I would like to change out my intake to make sure nothing happens. I recently purchased (two weeks) a 2000 F250 7.3L 141,000 miles and for the most part it is bare stock. The truck has the cool down shut off for the turbo and a K&N Intake. My question is, is it possible to simply change out the filter or do I need to change out the intake system? I did my searches and sorry if I missed it. I don't want to take up more space if there is a link already. Thanks for the help. |
Are you using the drop in filter or the cone filter with intake piping?
Either way, easiest and best bet would be the DIY 6637 filter. |
I am using the cone filter with the tubing. My thought was to use the DIY kit. What you're saying is the 6637 filter should fit on the existing setup or I need to do the whole 6637 setup?
IIRC, the k&n uses a 4 inch intake. So it should slip right on. The napa part # is 6637. I paid about $40 for it.
There's also a Donaldson filter that is basically the same one. |
