Coolant change and other stuff - Ford Powerstroke Diesel Forum
Old 01-27-2012, 04:39 AM
Mitch
I am heading out to Devils Lake, ND to go Ice fishing at the beginning of March and this trip makes me want to do a little bit of maintenance before I head out there. First thing on the list is a coolant flush and change. I have read to get a good ELC coolant (Cat ELC or IH). Where is a good place in central Wisconsin to get it from? I know I have to look for the EC-1 Rating on the bottle. I also plan on getting the different upper Radiator hose as well to go around the belt instead of through. Any body have a part number?
Any other things I should accomplish prior to trip? Anything that I should have with me?
Going to bring: Oil, fuel filter, CPS, check spare tire, and some other things.
Thanks!
Old 01-27-2012, 05:38 AM
The dual alternator radiator hose is Ford part Number F81Z-8260-CA. Check a cross reference through a parts store because they are ususally cheaper than the OEM. I bought mine from a buddy that works at a Ford dealer for $30 but I think they list for $40.
I would highly recommend going to the billet t-stat housing and 203° t-stat. You will see once you pull the stock housing that it will be a rusted pitted turd that won't seal again. And you'll love the extra cabin heat you get from the warmer running engine. Throw a gallon of anti-freeze and a qt of transmission fluid behind the seat and run it!
Also think about the coolant filtration system. When you do the flush you will find a disgusting sludge in the bottom of the degas bottle.
Old 01-27-2012, 05:56 AM
Ahhh nice.... I just signed on and was about to search for that number. Just so happened its the first post! Thanks!
Old 01-27-2012, 07:15 AM
You can get it for $15-20 from O'rielly's or AZ or the like...
Old 01-27-2012, 07:30 AM
Send a message via AIM to rufushusky
Thanks!
Any Napa has or can get their hands on Zerex ELC or Peak Final Charge, both of which meets Cummins 14603, Cat EC-1 and Navistar (international) B-1...ELC requirements.
I usually keep a quart or so of ATF with me w/ 3/8th hose hose menders...just in case. I would also keep a gallon of 50/50 coolant with you just in case.
Old 01-27-2012, 08:13 PM
Mitch
Sounds good! THanks for the help! Have the billet housing and t-stat on the shopping list. Current list:
Housing
T-stat
Coolant
Distilled water
Rad-hose
Old 01-28-2012, 06:28 AM
Ford sells an ELC that can be used in these trucks. It lists for about $13 a gallon.
Old 01-28-2012, 06:29 AM
They do?
Which one is that?
FCSD Chemicals and Lubricants
Old 01-28-2012, 12:01 PM
The premium gold
Premium Gold Engine Coolant with Bittering Agent
Old 01-28-2012, 02:23 PM
Well that is a long life coolant bit still requires testing and SCAs like green. ELCs, which meet EC-1, Navistar B-1 and/or Cummins 14603, don't need SCA testing nor SCAs. Both will work fine, I am actually running the Gold, it just needs a little more maintenance than an ELC.
