Standard boost levels on stock 7.3 - Ford Powerstroke Diesel Forum
Old 09-12-2007, 09:33 AM
I just bought a 2001 F350 4x4 with 170,000 miles and want to know what the turbo is supose to put out on a stock system? I have put gauges on it and at about 2300 RPMS with it floored I get about 15psi of boost. I am going through everything and want to make sure that everything is working properly befor I do any mods. Can any one tell me what boost level is the norm on the stock motor?
Old 09-12-2007, 09:39 AM
sounds about right without any mods.
My 99 with intake and exhaust will only hit about 18 and that is with a load going up a hill and being all over it. If you want more, just order a tuner of your choice. I'm sure others will be along to answer also.
Old 09-12-2007, 10:44 AM
Thats Mr. Oil Leak.....
15-18 is right for a stock truck.
Old 09-14-2007, 07:17 PM
yeah I was running about 15 before I did anything I can push right at about 27 wot
Old 09-14-2007, 07:25 PM
Send a message via AIM to Super Kaz
Mine pushed 15 stock, but with a tuner mine only go's to 19? Is that right?
Old 09-14-2007, 07:26 PM
Desert Shield/Storm Vet
That seems low even set on 2.
Old 09-14-2007, 07:29 PM
i have the bullydog 6 pos chip and i get 29-34 lbs of boost
Old 09-14-2007, 07:34 PM
Dam I got robbed
Old 09-14-2007, 07:38 PM
How does the truck run otherwise? Do you see lots of black smoke? Could be a small boost leak.
Old 09-14-2007, 07:44 PM
thats what I was gettin on stock tune16 or so..
