2 STROKE OIL - Ford Powerstroke Diesel Forum
Old 01-23-2012, 10:32 PM
2 STROKE OIL
I'm want to put 2stroke oil in my gas tank to lube everything up and maybe get some mpg... how much oil would i put in a tank? anyone else do this?
Old 01-23-2012, 10:35 PM
I've heard as little as an ounce and as much as a quart per fill up. I wouldn't go as far as a quart but there's a range for you. sorry I can't be more help than that
Old 01-23-2012, 10:36 PM
1oz of two stroke to 1 gallon of diesel. I use it periodically and it sure bumps my mileage and quiets my injectors down.
Old 01-23-2012, 10:41 PM
While I was reading on this subject awhile back I remember someone saying that not all 2 stroke oil is created equal. There is one that will leave some sort of black residue. Is this BS or not? Just something to think about.
Old 01-23-2012, 10:43 PM
Im pretty sure its tcw-3 outboard oil your supposed to use which is ashless.
Old 01-23-2012, 10:54 PM
^^^ Ditto. Buy it by the gallon at WalMart.
Old 01-23-2012, 11:01 PM
ill pick some up tomorrow thanks dudes
Old 01-24-2012, 12:02 AM
Get Red-line Oil RL-2. It's about $75 per gallon, but one ounce treats 20 gallons of fuel. Use it in every fill-up. It will make your truck very happy indeed.
Old 01-24-2012, 12:06 AM
Forgot to mention, you can also use Red-line Oil RL-3. Same oil, same benefits. Difference is the 3 has a cetane booster and you use one ounce per 10 gallons fuel. Same price per gallon but you use twice as much. I didn't see much notable difference between the two.
They both help to negate the effects of low and ultra-low sulfur.
Old 01-24-2012, 05:36 AM
Why not just use a good conditioner like Power Service Diesel Kleen? It has Cetane Boost and gives you a bump in mileage too. In the colder months it has anti-gelling properties too which I don't believe 2 cycle oil does.....
