Im doing an oil change on friday. I'm switching to amsoil fully synthetic 5w40, and amsoil trans fluid. what oil and fuel filter should i get? What should i switch my coolant to? i want the best possible fluids in my truck. also what differences would i see/ gain from switching these fluids? any help appreciated thanks guys
going to the 5w-40 you'll see better cold starts. and for the oil filter if you don't have to worry about clearance issues i'd go with elf7405. for fuel ive always just ran motorcraft
edit: i forgot to mention i'd do a coolant flush and go with cat elc. can find write ups on here about coolant flushes. and check out guzzle's page and look into a coolant filter. I've been needing to get this done too |
And I know someone is going to post...'I have been running Napa (wix) filter since 1863 and my truck has 91256456456156 miles on it and it is fine yada yada' I am not saying napa/wix are bad...I am just saying IMHO there are better filters out there for the money. As far as coolant, at least IMHO, ALMOST any coolant (green, gold, ELC...I would not even touch Dex-cool in an application that didn't spec it) properly maintained we serve your truck fine. ELCs are nice cause you don't have to worry about checking SCAs but green and gold ain't that bad either IMHO...just requires a little more work. While your at it you should think about changing your x-case (if applicable), power steering, diffs and brake fluid as well... Welcome to guzzle's Front Differential Maintenance Web Page Welcome to guzzle's Rear Differential Maintenance Web Page Welcome to guzzle's Transfer Case Fluid Change Web Page Ford Super Duty Power Steering Flush | Superdutypsd.com |
The EAO99 is 15 micron at 98.7% Amsoil EA Synthetic Oil Filters EAO99 The ELF 7405 is 15 microns at 98.7% https://dynamic.donaldson.com/webc/W...tml?item=80882 They are the same efficiency but the Donaldson is significantly larger than the Amsoil filter...it will support an extended drain interval just fine. It is designed for an engine with a sump that is 2-4 times the size of a PSD with a 7-10 times longer manufacturers recommended OCI. |
Hmm...what filter are you referring to here? Not really sure I am following what you are saying...are saying that Donaldson is inaccurate with its micron ratings or??
![]() Ok and what proof does Amsoil have for any of these fabulous claims? Any SAE, ISO tests at a 25k oci on a diesel engine? I only ask cause Donaldson, Fleetguard, Baldwin, Wix, Motorcraft, Champion..etc etc all seem to rate per industry standards (I can't think of the ISO off the top of my head) and it appears through their advertising, Amsoil is rating their filters on the same industry standard but alluding to performance that there doesn't seem to be an industry standard or common metrics for measuring. Which, to me at least, appears to be an advertising tool. Now I understand all manufacturers of any product, will always market its specs to make it look as good as possible...but how as we as end consumers verify these claims...we can't! Now on the same token we can't verify the claims of Donaldson or Wix directly either...however the ISO and SAE standards do provide the end user with a certain level of assurance since it is a third party that created these measuring standards...not the manufacturer. Ok I am off my soap box. ![]() Oh yeah the ELF7405 fits just fine on my 4wd. And one more thing....the ELF7349 (for the 5.9 Cummins) looks an awful lot like a Ea080 filter and has long been rumored to be the same thing... Donaldson Endurance vs. Amsoil EaO - Bob Is The Oil Guy
Hmm...ok, still no testing or proof really of any kind. Baldwin, fleetguard, Donaldson, Wix etc etc have used microglass and other forms of non-cellulose and synthetic media over the years.... |
Maybe with a dual-filter bypass AND UOA analysis. No spin-on filter is going to last 25,000 miles. |
Did the moderator delete 1/2 of this thread? I just joined the powerstroke family from the Cummins family. When my Dodge died Christmas morning (head on crash w/16 yo w/learners permit) it had 182,183 miles. I changed the oil & filter every 25,000 With amsoil 15 w 40 and a eao80. Always sent my oil out for test and always came back good. One thing the AMSOIL deaeler failed to mention was that Donaldson makes Ea filters for Amsoil. -Jason
First off, glad it was just your goat that bit the bullet, not its contents. Secondly, what a Cummins does to motor oil and what a 7.3's hpop will do to motor oil are two totally different animals. |
