Oil Cooler Seals
It looks like my oil cooler seals are leaking. How hard is it to pull the oil cooler to replace them? Any special tools or anything? Its on a 2002. Thanks
Also where is the best place to order the seals and gaskets? Last edited by nboeger4; 01-23-2012 at 12:02 PM. |
Mine too. Grab the gaskets from diesel o-rings as they are MUCH cheaper. Process is pretty easy as long as you can get to the front bolts. Most people losen the alternator and power steering pump after removing the belt and slide it forward a little.
Most difficult part is pressing the end caps back onto the cooler. Seen photos of people doing it with body weight and a piece of wood. Regardless, i do not plan on doing it myself. Id rather pay a shop for an hours worth of labor than have to deal with the fluids in the cold. No garage here. |
Ford wanted 600+ to do mine. So it looks like I'm doing it myself. It seems like some peole remove all kinds of stuff and others don't. But I know the oil has to get drained. Does all of the coolant have to get drained?
Just remove the oil filter, don't drain the pan. Unless you want to change the oil at the same time, it is not necessary. Draining coolant is required.
To reassemble I use a ratchet strap, works pretty easy. Remember to put some oil on the orings. |
Well the parts came in today. So it looks like I will be getting my hands dirty either tomorrow night or Saturday morning.
Well I got it done. Putting the new seals on the shaft was the worst part. And it was super messy but we had enough room to keep pushing the truck back to have fresh concrete to lay in. But sure beats paying the stealership to do it.
