New Truck!! - Ford Powerstroke Diesel Forum
post #1 of 15 Old 09-11-2007, 05:54 PM Thread Starter
tonypagnano's Avatar
Send a message via AIM to tonypagnano
New Truck!!
i just got a 1999 F350 single cab 4wd. It has a AFE intake, Boost and egt gauges, and magnaflow turbo back exhaust. The Pyrometer is ran in from the top of the downpipe, and the truck seems to run around 500-600 degrees. Is that normal tempetures? Also, it says the truck was made in 01/99. Does that make it an early 99 or a 99.5? thanks for the help guys.
tonypagnano is offline
post #2 of 15 Old 09-11-2007, 06:00 PM
SMKSTAX's Avatar
Congrats on the new rig!!
RICK
97 F350 CREW CAB 4x4, 7.3 TURBO DIESEL, DIY INTAKE , TW TUNES
GRAND ROCK POWERFLOW STACK KIT W/5" MITRES
3.55 REARS, 3" DOWNPIPE, FPR SHIMMED WITH GAUGE
SMKSTAX is offline
post #3 of 15 Old 09-11-2007, 06:04 PM
The Fat Mod
Logan's Avatar
Congrats on the new rig. Sounds like you have a post turbo set up, and that sounds about right for that kinda set up. Just becareful with your temps with your pyro there since it will take longer to heat up...it will also take longer to cool down. Sounds like you got an early build to me. Where does your intake get air from, and what kinda badges does it have? Get some pics of the new rig up when ya get a chance. Once again, congrats.
Logan is offline
post #4 of 15 Old 09-11-2007, 06:04 PM
Raul@Stealth Automotive's Avatar
Congrats on the new Rig
Raul@Stealth Automotive is offline
post #5 of 15 Old 09-11-2007, 06:07 PM
Awesome!!! Congrats on the new ride! I think the December and earlier makes are "early" 99 models... but if you can tell us about the intake and badges - we'll be able to help you figure it out!
Blue01F250 is offline
post #6 of 15 Old 09-11-2007, 06:08 PM
Don't mind me
westcoaststrokin's Avatar
Quoted: 3 Post(s)
Congrats on the new ride!!
Josh
04 F350 CC SB DRW IT HAS SOME STUFF
"Idiopathic, from the Latin meaning we're idiots cause we can't figure out what's causing it." House M.D.
westcoaststrokin is offline
post #7 of 15 Old 09-11-2007, 06:21 PM
Is it even worth it???
ABOBB's Avatar
Congrats on the new truck.
ABOBB
Aaron A. Bobb
2002 F-250 SD ExCab, Short Bed, PSD, Auto trans, 4X4
Custom tuned 6 position Chip
Whelen CSP690 Strobe Kit (Installed @ Feb Indy Strokers Rally... Thanks Adam), ZooDad Mod
COMING ATTRACTIONS:
Heated Side Mirrors, Owner Built Rear Airbag System
Owner Built Front Bumper, Owner Built Tymar Intake
Owner Built Custom Exhaust, Rear Roll Pan?
ABOBB is offline
post #8 of 15 Old 09-11-2007, 08:50 PM
Sorry to hijack for a second but how much of a difference is there? Reason why I ask is because thats where my probe sits as well.
99.5 F250
Airaid intake
4" Turbo back, straight
6" lift with 37" BFGs
Boost, Trans, EGT Gauges
Tirepaq
AIH delete
DP Tuner 40/80/120/140 with Gauge Switch
6.0 Intercooler
Foil Delete
Whicked Wheel
Billet T/C
Brand new Tranny
Zoodad Mod
6.0 trans cooler with 2 fan controlled coolers.
KCM S.S. HPX Line
Snow Performance stage 3 meth kit
Sinac is offline
post #9 of 15 Old 09-11-2007, 09:31 PM
Served Our Country!
HighOn20s's Avatar
Feedback Score: 3 reviews
Send a message via AIM to HighOn20s Send a message via Yahoo to HighOn20s
Congrats on the new toy!
USMC 96-00/0311
If you don't stand behind our troops, please feel free to stand in front of them.
2008 F250 Supercrew, Custom 14'' 4-link, F.O.A 2.5 Coil overs, 40/15.5R22 Toyo MTs on Hostile 22x14 Wheels, Yukon Lockers/4.56 gears,
PSC Hydro kit, H&S Mini Maxx with KEM 345 Tune, S&B CAI, TurboSmart BOV, No Limit Fab IC, EGR Delete w/ CSP, MBRP 5' exhaust, AirDog II, TransferFlow Tank, Rigid Industries Lightning!.
HighOn20s is offline
post #10 of 15 Old 09-12-2007, 12:00 AM
Powerstroke Techie
alabamafrog's Avatar
I believe yours is a 99.5. The temps can be 200 or more degrees difference between pre and post turbo. Mine varies in temp from 300 at idle to 1500 when stomped but usually cruises at 70mph around 600 on flat ground. Mine is preturbo which is the only way to go.
“Government, even in its best state, is but a necessary evil; in its worst state, an intolerable one” (T Paine)
Government cannot give anyone anything without stealing it from someone else. (A Frog)
alabamafrog is offline
