General questions, First time w/ a 7.3
just bought it just over a week ago, got a 2000 F250 Crew cab short bed 4x4 with the 7.3 I have had two diesels before this, just not a Ford, and never had gauages before either. so just in general whats normal and whats too much.
i have a EGT gauage and Trans temp gauage, I'm in Alaska and i know i need to cover my grill because my temp are too low, the trans temp will barely read on the hwy, but in town i've got it up to 140-160, which is not big deal. the EGT's I've maybe seen as high as 600. I not pulling anything yet, but just want to know whats normal and whats too much for the trans & EGT. the rig is stock far as I can tell, no muffler and a lift is all I can tell, not even sure how much lift 4-6 maybe running 35's. just would like some input, and got just a little bit of a light blue smoke until it gets warmed up, i've done some looking, should I be worried, do i need to bring it in??? thanks for any help I can get. |
and since i dont know whats been done to this rig, with 143,xxx miles on it what types of maintence should I do??? i plan on changing all the fuilds, and over to synthetic, both diff's, transmission & transfer. I've heard and read how great they are, and with the cold of Alaska proably not a bad idea. did the oil and fuel filter. Is 10w-30 to much for up here, i plug it in but plan to add a oil pan heater, and of course Rotella oil.
any common repairs around this mileage? or miles to come? |
600 egt is fine once u hit 1200 pistons and stuff start to melt, but flashes of 1200 1300 are fine for a few seconds, switch to fully synthetic rotella my truck starts fine at 0 degrees, but Alaska is colder I don't think u need a oil pan heater ur block heater should do the job once you switch the oil
The EGTs depend on where the probe is mounted. If it's mounted in your down pipe, that's bad, m'kay. It needs to be mounted in your manifold. You're saying you've never seen temps over 600, which leads me to believe that it is mounted in your down pipe, as most people are around 600 degrees cruising on the highway. For oil, I'd go with 5w40, or if you can find it, I think Rotella makes a 0w40.
I forgot about the manifold and dp, dp 600 is way to high 600 manifold is ok depending at what speed/rpm
I also am a new PSD owner, i did a lot of searching on this forum and also on the internet. the best thing so far that i have found that should answer alot of your questions is going to powerstrokehelp.com this guy has a ton of videos on everything you can think of on your 7.3. take a look and let me know what you think.
That guy is an idiot... Don't listen to him I'm surprised he know how change oil
Hey, he can change the HPOP oil.
You beat me to it
![]() The guy is . . . ok. He documents a lot of stuff, which is helpful. But past that, don't listen to him. |
