911 Help! Chip problem - Ford Powerstroke Diesel Forum
Old 01-21-2012, 12:28 PM
Exclamation 911 Help! Chip problem
Installed my Dp Tuner today that I bought used and sent to Jody for a reflash. The install was a success and it is awesome! However my truck is currently down! The first time I started the truck it was flawless. Drove it around and had a little fun, then shut truck off only to get a no start (Check engine light came on and no wait to start light). So I took the chip out, cleaned the connections on the PCM and reinstalled. This worked and the truck started. Drove around a bit then shut it off again. I tried to restart the truck and the same story, I got a no start. I need some help pretty bad. Anyone know the answer to this problem?
Old 01-21-2012, 12:50 PM
Basics first -
* Are you now getting the WTS light?
* Is the tach moving as you crank it?
* Any white smoke?
* Is the chip in it now?
Old 01-21-2012, 01:01 PM
OK just went to try again and it started fine. Then shut off, pulled key, and tried again. No start! No WTS light, no tach movement, no white smoke, and the chip is infact in now. I did take the chip out for a bit and it started and ran fine. But with the chip its like it only wants to start once, then not anymore after that.
Old 01-21-2012, 01:02 PM
Feedback Score: 5 reviews
When you plug the tuner into the PCM, (WITH THE TRUCK OFF, KEYS OUT OF THE IGNITION) try re-installing it without the black box, and tape it in place with duct tape or electrical tape.
Old 01-21-2012, 01:16 PM
Yea, i used duct tape. Its in there tight. Cleaned the connections twice. I also noticed that the previous owner had the dealership do something to the PCM. The silicon was already rubbed off the connections. And there is a sticker under the hood from the ford dealership that is faded. All I can make out is the word PCM. What do you think this is? Could this be the issue? I had Jody tune it for an early 99 XLE8 PCM.
Old 01-21-2012, 01:23 PM
Did you mount the PCM with the black box?
Old 01-21-2012, 01:26 PM
Yea, the PCM is installed in the factory black box just the way the DP directions say.
Old 01-21-2012, 01:30 PM
Ok, here is where I am coming from:
When I installed my PHP chip, I was having issues similar to yours. It would work...die...then would not re-start until I removed the chip and/or PCM. Chased it for a while.
Turns out, the black box was putting just enough pressure on the chip to turn it, causing it to essentially shut down the PCM.
I have since removed the black box, and haven't had a problem since.
It would at least eliminate it as a possibility for you.
Old 01-21-2012, 01:34 PM
I will try this, but my truck never died on me. It only would not restart after the first time running.
Old 01-21-2012, 01:37 PM
It only does it with the tuner on, right?
