egts - Ford Powerstroke Diesel Forum
Old 01-20-2012, 01:21 PM
egts
I installed my 4 inch turbo back exhaust and bow it seems like my egts are reading out about 100* higher than what they were with the stock pipe and muffler delete. I'm thinking my pyro may be messed up as I had problems with it bouncing around earlier this weel but OS there anything I could be over looking that would cause a 100* change. Didnt find any. boost leaks when I checked
Old 01-20-2012, 05:25 PM
Update: going 45mph its at 700* before it would b under 500
Old 01-20-2012, 05:55 PM
When you say bouncing around you mean your gauge? that really sucks, no way something was blocking the flow part way off?
Old 01-20-2012, 08:03 PM
Only thing I could think would b the ebpv. The gauge would jump random numbers between 500 and 1700. I fixed that and it read out a little cooler than it used to like I figured it should since the 4inch turbo back exhaust got put on but today it seemed to read hot I know something isn't right because at idle it doesn't go below 300 and it used to but it doesn't have to sound of the ebpv closed.
