Fuel Tank or Fuel Gauge Issue? - Ford Powerstroke Diesel Forum
post #1 of 13 Old 01-16-2012, 05:22 PM Thread Starter
Chad Kay's Avatar
Between 1/4 and empty lines on fuel gauge the other day I ran out of fuel, could the float in the tank be stuck or is this a gauge issue? I done the fix on the overhead gauges 2 days ago and right now at 1/4 tank of fuel left it says 130 miles till empty, this doesn't seem right or could the overhead gauge be off also?
Thanks Chad
Chad Kay is offline
post #2 of 13 Old 01-16-2012, 05:25 PM
jesilvas's Avatar
Quoted: 3 Post(s)
The gauge and OTC both use the PCM to come up with that number.
Do you have non OEM size tires/wheels?
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 13 Old 01-16-2012, 06:45 PM
codyryan07's Avatar
Could be a crack in the pickup valve in the bottom of the tank sucking in air causing you to run out of fuel and your gauges still reading. Had this same problem a few months ago, mine was broken and rolling around the bottom of my tank.
Cody Ryan
03 f250 ccsb fx4 7.3
4" RC lift
35x12.50 federals on 20x12 rockstars
6637 intake, straight pipe
full RR w/ fuel bowl delete.
rebuild coming soon
codyryan07 is offline
post #4 of 13 Old 01-18-2012, 04:09 AM Thread Starter
Chad Kay's Avatar
Yes I'm running 285/75/16 TA's.
Chad Kay is offline
post #5 of 13 Old 01-18-2012, 04:10 AM Thread Starter
Chad Kay's Avatar
What's the easiest way to fix this, drop the tank down?
Chad Kay is offline
post #6 of 13 Old 01-18-2012, 05:04 AM
GAS
GAS's Avatar
Yep drop the tank(empty)
good excuse to install this Driven Diesel 7.3L Fuel Tank / Pre-Pump Kit
It bypasses the offending valve, adds a filter, and goes along way to keeping air out of your injectors.
Micha, Pleasant Grove, Utah
99 F350 Crew cab long bed, Tymar intake(The real deal)
Zoodad, 4 inch exhaust, Dipricol gauges, WW,
gutted turbo pedestal and ebpv deleted big exhaust outlet, ccv delete
GAS is offline
post #7 of 13 Old 01-18-2012, 09:23 AM
codyryan07's Avatar
You could do either that or http://www.guzzle7pt3.com/hutch.php Both will help a lot... if you still have your stock fuel bowl you can use just a small inline wix filter from napa.. I don't remember the number but its about $10. While your in there might as well do the harpoon mod. I build my hutch mod kit for roughly $25-30.
Cody Ryan
4" RC lift
rebuild coming soon
post #8 of 13 Old 01-18-2012, 09:30 AM
codyryan07's Avatar
Here's a helpful link to dropping the fuel tank Dropping Fuel Tank also the wix filter #33270, IIRC.
Cody Ryan
4" RC lift
rebuild coming soon
post #9 of 13 Old 01-18-2012, 10:42 AM Thread Starter
Chad Kay's Avatar
OK thx guys. May try this weekend to get er done.
Chad Kay is offline
post #10 of 13 Old 01-18-2012, 11:35 AM
codyryan07's Avatar
Btw, if your pickup foot is broken or cracked, you should be able to order it from a dealer for roughly $45. That's what I paid for mine, but if you have some extra time to wait than you could order one through guzzles site.. he should have a link posted for it.. its a simple job with basic tools, but if you have any questions you can pm me, and I'll be glad to help!
Cody Ryan
4" RC lift
rebuild coming soon
