trailer tow charge relay
I think my trailer tow charge relay has gone bad. i have no power to the trailer. in fact there is no power to the plug on the truck. i have checked the fuses and they are good. But i have no idea which one is the charge relay. anyone know?
I have a owners manual for a 99 Stroker. It shows in the cab the trailer tow battery is the number 24 with a 10 amp fuse. Also I the power Dis box under the hood the number 16 with a 30 amp maxi fuse . When I first got my truck I had the same problem. Changed out the fuse and all was well. Hope this helps. If not post and someone will lend a hand.
99 Red Stroker |
did you change it cause the fuse was bad or just changed it and it worked. i checked both fuses and the were still good. this is why i thought it might be the relay. thanks for the info though.
I changed my 30 amp maxi fuse. It was bad and fixed my problem. It may be your relay. I'm not sure how they are set up. Maybe someone will chime in and help. I'm not a tech
and there are several on here that are great about jumping in with the answers. Good luck and keep posting and the help will come. 99 Red Stroker |
Do you have lights to the truck? If you do then its probobly a wiring problem.
Oh never mind sorry your not talking about the lights
