Front right brake locking up easily
Feels like a abs issue,no lights or codes are on.If you hit the brakes kinda hard the abs kicks in and the front right wheel starts locking up.I bleed the calipers on the front,anyone have a similar issue,I have a p/s leak also,sometimes the power steering goes out and ive found a leak on the bottom of the pump/high pressure hose-could these be related?
You should check the hub bearing if it is loose it could cause an issue.
My right front locked up sometimes..the left front brake line was plugged. I changed it but a month later had to do the right also, then both calipers. The truck had been sitting for a while.
any other thoughts?
