Quick Gauge Help - Ford Powerstroke Diesel Forum
Old 01-09-2012, 05:27 PM
Quick Gauge Help
I finally got around to wiring up my gauges and the only thing I am having trouble figuring out is what I do with the 2 wires that run off of my transmission sensor. There are 2 orange wires that i ran through the fire wall but I am not sure where they go
Also, I tried to do a search but was unable to find it. What are the proper operating temperatures of the EGT and Transmission?
Thanks for the help guys!!
Old 01-09-2012, 06:43 PM
Does the back of your guage have two screw terminals opposite each other, and not the long silver ones that are used for mounting in something other than a guage pod? Those wires I am guessing have a ring terminal on them and each of the two slide onto its own screw terminal. I cant remember if it matters which one goes on which side. Does you still have your installation sheet that can explain which goes where?
Old 01-09-2012, 06:44 PM
On mine, one was a signal and the other just a ground. Not sure about them if they are both orange. What brand are they?
As for temps...... here ya go.
Optimal running temps,boost, Pyro,Trans readings.. anything readings...
Old 01-09-2012, 07:10 PM
I am pretty sure it has two screw terminals. The wires do not have any terminals on them but it would not be a big deal for me to add them. I thought i still had the installation sheet but cant find it anywhere. The way i am thinking, one of the wires has to tell the gauge what the reading and the other wire is a ground but I am not sure.
That is exactly what I was thinking but wasnt sure. Not sure where to wire them though....The gauges are isspro ev's
Thanks for the link, thats exactly what i was looking for!
Old 01-09-2012, 07:13 PM
Oh. I have autometers so ours would not look the same. Have you tried searching google for installation instructions. You would be surprised what is available out there. Good luck.
