Wheres the chip - Ford Powerstroke Diesel Forum
post #1 of 8 Old 09-09-2007, 06:09 PM Thread Starter
Wheres the chip
I bought a 2001 F350 7.3 , It supposedly has a power chip. It is not pluggeded into the obd2 plug, it is not plugged into the ICP sensor, where else are these chips hiding. I want to find it to see what / if I have, before I can see what I need or what is compatable. I am sure this is an old thread but I haven't found an answer in the FAQ or old postings.
I am new to diesel. My main interest is pulling a 30' 5th wheel and getting better milage when I am not towing.
vbivans is offline
post #2 of 8 Old 09-09-2007, 06:11 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 9 Post(s)
The PCM is on the drivers side kick panel behind the emergency brake its a black box
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #3 of 8 Old 09-09-2007, 06:12 PM
duct tape & zip ties
bigcountrysg's Avatar
It most likely is located in the ECM or PCM what ever you want to call it. On my 2002 it is located on the firewall, under the dash on the driverside by the e-brake. I believe it is located in the same spot for the 2001's.
Your Actions Today, Decide Your Future Tomorrow
2005 6.0 Crew Cab Long Box Lariat, current truck
2004 6.0 destroyed by contaminated fuel
2002 7.3L burnt
bigcountrysg is offline
post #4 of 8 Old 09-09-2007, 06:21 PM Thread Starter
How is it removed or opened. I see two bolts holding the front into the bracket but how is it connected at the firewall end
vbivans is offline
post #5 of 8 Old 09-09-2007, 06:23 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 9 Post(s)
under the hood on the firewall in the area that you see the PCM there is a wire harness with i think a 10mm bolt i could be wrong on the bolt size take that bolt loose it should slide out
Email:
Edge Insight CTS
Coolant filter
Dave is offline
post #6 of 8 Old 09-09-2007, 06:24 PM
No your correct quadracer. 10mm bolts.
2002 7.3L burnt
post #7 of 8 Old 09-09-2007, 06:26 PM
rankroddin250's Avatar
go to the mod help forum. I think maintan pasted a movie on how to install a chip in a superduty that would helpo ya out
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
The People of a free country should not be scared of their government, the government should be scared of their people.
rankroddin250 is offline
post #8 of 8 Old 09-09-2007, 06:31 PM Thread Starter
Thanks for the help
vbivans is offline
