Stage 2 single shots - Ford Powerstroke Diesel Forum
Old 01-09-2012, 02:38 PM
I'll be installing stage 2 160cc single shots soon but what will I need as far as fuel goes do I need to upgrade from tank to motor or just reg return or just built my own fuel system? Thanks for input
Old 01-09-2012, 09:21 PM
You will need a custom tune for the single shots.
Old 01-10-2012, 03:26 AM
Yea bill at php is only 20 mins away so I'll get live tuned once I get them installed I was wanting to know what I will need on the fuel end of it?
Old 01-10-2012, 04:32 AM
Chapter Director
Bill is amazeing he tuned my truck at his house
Old 01-10-2012, 04:46 AM
A regulated return and oil xover will help feed those injectors. You'll be pushing the limits of your factory HPOP.
Old 01-10-2012, 04:57 AM
The single shots use less oil then the split shots dont they?
Old 01-10-2012, 06:34 AM
yes they do. I'd still look into a modded hpop.
Old 01-10-2012, 08:16 AM
Yea I'm putting in a t500 at the same time I was thinking a reg return with fuel bowl delete and pre pump and post pump with the hutch and harpoon mods but is the stock feed line big enough to keep fuel to the motor?
Old 01-10-2012, 12:18 PM
someone correct me if I'm wrong but i think i read on here that with stage 2s (may be stage 3s) its benficial to move up to 5/8th fuel line to keep the injectors fed. im not positive on this so hopefully someone can chime in and correct me if im wrong
Old 01-10-2012, 05:08 PM
Yea maybe somebody that is running them will chime in cause I only want to do it once and the right way
