Put 1 gallon of Rotella 10w40 and seems like it cranks too long...
Well the truck runs and drives fine, this past oil change and fuel filter change i went with 1 gallon of 10w40 and the rest 15w40 rotella because its supposed to be real cold this winter... first time ive done this, i had 3 gallons of this stuff and now only one truck.
So, the truck has brand new batteries and when i first fire the truck up it seems to crank longer than normal before it actually starts. Say its like 20° outside and the truck isnt plugged in, it cranks for 5 seconds or more, the glow plugs work fine. I was wondering if it had anything to do with the thinner oil i put into the truck? Anyone else use 10w40 on their 7.3? Well, i had bought a 6.0 and the oil came with that truck, now the trucks gone i have 3 gallons sitting on the shelf for over a year... Just wondering if the oil was keeping the injectors from firing off sooner. Thanks |
I've never heard of 10w40 Rotella? I've only seen the 5w40,10w30, and 15w40?
Anyways, have you checked to see if your glow plug relay is still putting out a good voltage?
never heard of any1 using 10w-40...i use Amsoil 5w-40 all year long in my 6.0L !!!
Hey thanks for the replys guys.... I screwed the pooch on that one, you guys were right. 10w30
![]() I just went to check the relay. Battery voltage key off. 12.4 Relay output 10.60 volts when its firing up the glow plugs. Truck fired up right away, its 40° outside. Battery voltage when alternator is kicked on, 13.1 and slightly raising but i shut the truck off asap. Maybe im just thinking its cranking longer with the lower viscosity oil. If it had a few bad glow plugs, is the only way to check them to take them out? I know its had all 8 put in about 6 years ago. Whats the life expectancy of these ford glow plugs? |
you want to use a 5w40 oil in the winter its thinner
You can ohm the glowplugs with a multi meter without removing them. Search for it on here.
Is your relay stock? I use rotella 5w40 year round. I'm in Utah been low 20s high teens not too cold but that oil makes a huge difference in starting for sure. If you have the stock relay go take that out and toss it they are ****. Stancor relay is the way to go for sure.
Sent from my ADR6350 using AutoGuide.Com Free |
Shell Rotella T5 10W40 Synthetic Oil, 1 gal. - 8030156 | Tractor Supply Company like others have said I would check your GPs and GPR...mine was putting out 3 volts. I got a stancor on the way. |
But the batteries are 1 month old interstates with like 800 cca each. The batteries were 3 plus years old and went south, got them replaced for free thru our battery company, i cant complain about that. That was a 200.00 plus christmas bonus the battery company saved my butt |
Nevermind, i did some research, that stancor relay is just a white rodgers 12 volt relay.
I dont think it will put out more voltage/ cause less draw to the glow plugs. If i go with one, ill just get it at graingers Thanks for the tip i appreciate it. BW |
