Injector noise? Cackle? - Ford Powerstroke Diesel Forum
Old 01-04-2012, 06:29 PM
So I've def been down on power lately and noise seems a lot worse than
Usual. It started yesterday when I was running late I usually baby it when cold I get a lot of scary noise and don't know what it is. I don't like not knowing it scares me. Anyways yesterday was the first time I've heard this noise and would really like to know what it is ( ps first time I heard this it was much worse than this time"") well anyways hoping for feedback truck has been cold both times and is stock besides straight pipe early 99
Old 01-04-2012, 06:58 PM
sorry hear is the sound clip what does it sound like to you?
Old 01-04-2012, 07:05 PM
how do i post a video cause it doesn't seem to be working?
Old 01-04-2012, 07:53 PM
Just post a link.
better than nothin!!! Lol
Old 01-05-2012, 11:05 AM
Ok here we go just let me know how it sounds really hard to hear what I'm talking about
Old 01-05-2012, 11:59 AM
I didnt hear anything unusual.
Don't rely on me though!!! Lol
Old 01-05-2012, 12:04 PM
sounds normal to me too
Old 01-05-2012, 12:20 PM
Anything from air in the lines, crappy fuel, old oil, fuel pressure, etc. Sounds fine to me as well. mine is MUCH louder.
Old 01-05-2012, 12:33 PM
ya i was thinking if he was hearing anything it was probably air in the lines
Old 01-05-2012, 01:00 PM
Do you only notice the cackle when the truck is cold meaning not up to operating temp?
Do you have hard cold starting issues?
If you answer yes to the above questions you may have a injector or serveral injectors starting to stick a little or possibly alot.
The only way to properly trouble shoot sticking injectors is on a cold engine you will need to remove the valve covers and look at the oil spouts when it is running you should see an even amount of oil coming from all injectors. If one has constant flow that is a bad injector, no oil flow is a bad injector. A good injector will just spit some oil as it fires
the injector.
I could not hear too much on the video as the others.
I drove a truck with bad injectors in it and my truck has injectors that are sticking when cold.
When it is cold out there may be a valve on your truck that will create exhaust back pressure to aid in the warming up the engine. If your truck has that it causes a loss of power until warmed up to operating temp.
