Injector Install - Ford Powerstroke Diesel Forum
post #1 of 8 Old 01-03-2012, 02:23 PM Thread Starter
Jordan72's Avatar
Injector Install
Hey guys I'm going to be installing my new injectors tomorrow and was wondering if there are any hints or tips or even links to write ups/ videos that may help things go smoother. I did glow plugs last year so I have had the valve covers off before also...
What are the 2 allen head plugs that you pull for? and Is the best way to get the oil out of the heads just to pull the glow plugs and turn the truck over for a little while?
oh and also when I install the new injectors I just dip them in oil before i put them in?
thanks in advance
Early 99' CCLB, 05 Harley Front End, 05 Harley Black Leather Interior, 05 Lighted Tow Mirrors, Built Trans
Jordan72 is offline
post #2 of 8 Old 01-03-2012, 03:27 PM
Quoted: 156 Post(s)
Feedback Score: 3 reviews
NoRalPh is offline
post #3 of 8 Old 01-03-2012, 04:09 PM
Fordman99's Avatar
Dont be afraid to break just pry those things out
E-99 f250 x-codes BD performance trans 35/12.5/15 mudders straight piped ......more to come
other car 2000 Lincoln ls v8----SOLD----
Fordman99 is offline
post #4 of 8 Old 01-03-2012, 06:19 PM
GAS
GAS's Avatar
Sure you can crank the engine over with the glow plugs out to get the oil out, but,, Even if you turn it over by hand it's going to make one hell of a mess.
At the very least, put the valve covers back on to help contain the mess. If possible, use some method to suck the oil out. I use a home built vacuum reservoir, powered by the vacuum pump i use for air conditioning work.
Micha, Pleasant Grove, Utah
99 F350 Crew cab long bed, Tymar intake(The real deal)
Zoodad, 4 inch exhaust, Dipricol gauges, WW,
gutted turbo pedestal and ebpv deleted big exhaust outlet, ccv delete
GAS is offline
post #5 of 8 Old 01-03-2012, 07:22 PM Thread Starter
Jordan72's Avatar
yeah maybe ill put a little piece of hose on the shop vac and tape it to hell around the end... then just shove it in the hole at the bottom of the injector cup?
Jordan72 is offline
post #6 of 8 Old 01-03-2012, 08:32 PM
GAS
GAS's Avatar
1/4 inch hose that is used for swamp coolers and such, fits right though the injector tip hole so you can get at the oil collected in the cylinder and piston cup. Sucking directly into your shop vac would ruin your vac filter. However the shop vac would work great to put a suction on a clear glass jug or similar, then extend the 1/4 " hose from that container. make sense?
That way you can dump out your collected fluid from the jug and not gunk up the shop vac.
GAS is offline
post #7 of 8 Old 01-04-2012, 05:37 PM
Fordman99's Avatar
+1 on the shop vac it won't hurt it I've done it and a lot worse as is cleaning out clogged up 4" sewage pipes many times. Trust me that is a lot worse than a little oil in there it all washes out in the end hense the term "wet/dry vac"I
post #8 of 8 Old 01-04-2012, 05:38 PM
Fordman99's Avatar
Oh and I used 1/4 copper pipe just be easy don't want to scratch stuff up
