fuel gauge no workie? - Ford Powerstroke Diesel Forum
Old 12-29-2011, 08:08 PM
Hi, my fuel gauge shows full, on the mark, I put in 20 gallons and no change? Where would a good place to start looking? Is this usaul for this truck? Thanks, Artie
Old 12-30-2011, 12:52 PM
Send a message via AIM to rufushusky
You could just just disconnecting the batteries just to reset the ECM, if that doesn't work sounds like your sending unit just bit the bullet.
Old 12-30-2011, 01:28 PM
I swear this question pops up like every month. It is a common problem and NO ONE on any psd forum has ever answered it. Mine does the same exact thing.
If I ever get around to it Im gonna do a full right up with pics and a video on how to fix it. The fuel sending unit is the culprit. You can either drop the tank or pull the bed off. I havent decided which one to do. Either way you can kill three birds with one stone when you are inside that tank so it is worth it (sending unit replacement, hutch mod, and harpoon mod) search the forums for what those are.
Some say beat on the tank with a hammer, drive over rail road tracks, SCREW that ive seen a couple of trucks with stuck floats and that fixed the problem but 80% of the problem is the bad sending unit. Id check the wires real good, ive heard a bad ground could cause a false reading also. Just some thoughts, when it gets wamer and life slows down Ill try to fix it with a write up.
Good luck
Old 12-30-2011, 03:55 PM
OK, that's what I wanted to know, if I pulled the tank connector would the gauge drop to empty?
Old 12-30-2011, 07:06 PM
Bad ground will show full, but its probably just a bad sending unit. Mine does the same but Ive been just driving it to 300 miles and just filling it every time. Makes it a little more iffy when youre pulling a trailer though lol
