My new '02 - Ford Powerstroke Diesel Forum
post #1 of 7 Old 12-27-2011, 03:31 PM Thread Starter
6.0Powerjoke's Avatar
My new '02
I had a '07 6.o that was short lived. Flipped it on the highway last winter after making 3 payments on it. Anyway, I just recently bought a 2002 Lariat 4 door long bed 4X4 with the 7.3/auto. This truck is in amazing shape! It's been kept in a heated barn since 2005 and has a maintenance record a mile long. Runs good, shifts good, and looks good. However it drifts a little on the road and I'm thinking one or more of the tires might be out of round, it seems to hop a little between 40 - 45mph. I read some of the suspension Threads on here and looking at the truck the inside edges of the front tires are worn so I suspect it needs an adjustment. Also maybe I'm looking at it funny, but the drivers side front tire looks like its leaning into the wheel well, How likely is it that top ball joint, or king pin or what ever the hell the technical term is, how likely is it that thing is causing the tire to lean in and possibly throw all of the other angles off? and how much of a job is it to replace that joint? I imagine the wheel, brakes, axle shaft and the steering knuckle will all have to be removed. Any tips or tricks would be cool.
6.0Powerjoke is offline
post #2 of 7 Old 12-27-2011, 08:40 PM
Zaairman's Avatar
Quoted: 12 Post(s)
How many miles are on it? Doing ball joints is definitely a job, but can also be done in your garage... And you're right, you've gotta pull the brakes, axle shaft, and steering knuckle. And you need a special tool to install the new axle seal. Do both the upper and lower ball joints on the same side at once. It makes zero sense to do just one, plus, you've gotta remove the lower to get at the upper anyways.
Zach
2000/2006ish Ford F-250 Larryette 7.3 Powerstroke 4x4
5" Sewer Pipe Exhaust
, DIY 6637 Intake, Wicked Wheel'd, De-foiled, Missing EBPV, Edge Juice with Attitude, Few leaves added here and there, 35" BFGs, 16x10 Eagle Alloys, Alpine W200
SLAPS Member #153
Zaairman is offline
post #3 of 7 Old 12-27-2011, 09:08 PM Thread Starter
Smile
It has 129,510 miles on it right now. I also may have lucked out. The drivers side tire just looks crooked in my driveway. So I found some level ground and jacked up each tire and moved everything around. No play in anything, so I pulled a tape from the inside edges of the tires and found that I had 60 1/4" on the front and back inside edges of the front tires. So I adjusted the drag link till I had 60 1/8" on the front of the tires and 60 3/8" on the back side. Took it for a drive and it tracked straight as could be. No more wobble, and no more drifting. I'm happy now, might just wax this thing now.
post #4 of 7 Old 12-28-2011, 05:42 AM
Zaairman's Avatar
Quoted: 12 Post(s)
If the ball joints haven't been done yet, it's probably getting close to needing it...
Zach
SLAPS Member #153
Zaairman is offline
post #5 of 7 Old 12-28-2011, 07:31 AM Thread Starter
That might be a good project for spring. My K5 puked it's spider gears out of the rear end last month, and I'm a Chevy guy, so it takes priority.
post #6 of 7 Old 03-05-2012, 04:56 AM Thread Starter
New brake pads, Rotors, sway arm bushings, and a slight drag link adjustment took care of everything.
Beware of the underdog!
post #7 of 7 Old 03-05-2012, 04:44 PM
Codum's Avatar
I have only done ball joints on two superdutys, mine at 300k miles and my brothers at 412k miles, so I would not change them unless I new they where bad. It is a tough job on these big trucks, but yes can be done in your garage.
2014 F250 CCSB 6.7
80 gallon fuel tank in bed
"We Farm for Ducks"
2005 Excursion Eddie Bauer 4X4 6.0
Stock 245k miles
Codum is offline
