Steering stabilizer boot - Ford Powerstroke Diesel Forum
post #1 of 4 Old 12-24-2011, 04:14 AM Thread Starter
revolvingsteel's Avatar
Anybody know why I couldn't cut the ugly blue boot off my moog steering stabilizer? Would it dramatically shorten the lifespan of it?
Early 99 F250, Tuned by Gearhead, Diamond Eye 5", DIY intake, GS EGT/Trans/Boost, FRX, HPX, CCV, Schaeffers 9000, ELF7405, Stancor
Next: A Better Trans Cooler, 35"s
revolvingsteel is offline
post #2 of 4 Old 12-24-2011, 06:30 AM
Govy Magnet
zambonimaxx's Avatar
Pitting from rocks and stuff hitting the actual dampening shaft, that would be the only negative could start leaking eventually that way if it's a hydro.
-Phil
"Initial Success or Total Failure"
2002 F250 SC SB 4x4 7.3ltr
~leveling kit~35/12.5~B&W~MBRP 5"~4 Pod Gauge Pillar ~TW 6 POS~Mag-Hytec~LineX]~KC Long Range (Front)~KC Wide Beam (Rear)~Cobra CB~WW~CFM+~EBPV Delete ~6kHID's~OUO Blocks~3/4" Ubolts~OUO Adjust ladder bars~Full RR system w/ Fuel Bowl Delete~ CCV~BTS TRANNY
~ 6.0 Tranny Cooler ~ BHOF/Coolant Filter/ Fltr Mags
2012 Harley Davidson FXDB
2010 Jetta TDI traded for...
2012 Chrysler Town & Country
zambonimaxx is offline
post #3 of 4 Old 12-24-2011, 07:42 AM Thread Starter
Hmm, decisions. The factory damper is exposed correct?
post #4 of 4 Old 12-24-2011, 03:53 PM
I would say the boot is there for a reason and unless you like paying for and replacing the stabilizers alot I would leave the boot on.
Pulling off the boot will probaly void the waranty making you have to pay for the replacement.
mgassel is offline
