10 mpg winter fuel??? any one else
i use to get about 14 mpg around town in the summer now in the winter im getting about 10ish. i also just put on 33in mud tires in the summer i had stock size ats. any one else getting 10 mpg in the winter. im thinking about changing the air filter and fuel filter???
You have a lot of factors to look at. Filters are a good start. The larger tire will not help plus it will throw the speedometer and odometer off which in turn gives you a false MPG reading. 4MPG is a bit extreme for #1 but 1-3 MPG is not unheard of when switching from #2 to #1.
Ive noticed i've lost about 2mpg since we started getting colder weather.. Although I do not know if they've actually switched to winter fuel here in south Texas yet.
Are you calculating the difference in tire size?
no im not how would i go about doing this. the truck runs geat i dont think its any injector issuses starts right up in the cold
Normal to get lower fuel economy with winter diesel that's why a lot of big rigs have tank heaters and heated fuel lines so they can keep using summer diesel a lot longer.
Tire size calculator Then, whatever the difference is, add that % to your miles driven. And make sure you fill the tank up all the way. |
im not good at this math stuff im sure if i tried hard enough i would get it but... it says is 3.7% slow
im going to start useing the gps for my miles
you also let it warm up more and idle more when its cold out. when youre sittin still and the engine is runnin youre gettin 0 miles per gallon
