PCM tuning questions - Ford Powerstroke Diesel Forum
post #1 of 10 Old 12-20-2011, 09:44 PM Thread Starter
I have a 2000 f350 4x4 with a 7.3 automatic. I just had new stage 2 single shot injectors, HPOP, and 38r turbo put in my truck. Im using a beans tuner and the truck is hard to start when its cold, doesnt feel like its got alot of power, romps when you first start it, and romps when you get off the gas when getting off highways or coming down from higher speeds. Also wont blow almost any smoke no matter what setting the chip is in.
-without the chip.. it starts alot easier, sounds better when driving, & has more power, but as soon as you go below 25mph it starts to romp/chatter; accelerating the slightest bit makes it stop.
-Ive plugged in my old tuner for the stock injectors into the truck; it adds HP, feels good, but has the same issues as without the tuner, just worse.
-with the beans tuner, the EGT stay low (never seen it get above 950). with the old one EGT is around 800 with daily driving.
I've had the chip reburned 3 different times to make sure it wasnt a faulty chip, so I know thats not the problem; also got new chip altogether instead of keeping same one.
Is there any way that the tune could be for a different PCM? I never gave my PCM # to the guy who tuned it, but he said all 2000's are the same? or do you have any idea what could be causing this?
FL_Cracker is offline
post #2 of 10 Old 12-21-2011, 09:17 AM
duck fan's Avatar
Did you have the tunes redone for the new injectors?
2005 F250 CCSB FX4 6.0
2003 Excursion 6.0 4WD
1997 F350 CCLB 4WD 7.3
1996 F250 SCLB 4WD 7.3
duck fan is offline
post #3 of 10 Old 12-21-2011, 10:02 AM Thread Starter
Yes, didn't have the tunes til after.
post #4 of 10 Old 12-21-2011, 10:49 AM
duck fan's Avatar
How many miles since the mods?
duck fan is offline
post #5 of 10 Old 12-21-2011, 12:23 PM Thread Starter
Around 6k. Hasn't gotten better or worse.
post #6 of 10 Old 12-21-2011, 12:46 PM
duck fan's Avatar
Gotta suspect the tuning then. Call whoever wrote your tunes. Or try someone else.
duck fan is offline
post #7 of 10 Old 12-21-2011, 01:31 PM Thread Starter
I had the tunes reburned 3 times on 2 chips and tried someone elses tunes that felt even worse. Do my problems sound like the tunes could have been written for the wrong PCM or maye the mechanic didn't put the right injectors.
post #8 of 10 Old 12-21-2011, 03:02 PM
duck fan's Avatar
Yes, both things are probable.
Edit: Also, unplug the ICP sensor and check the connector for oil
duck fan is offline
post #9 of 10 Old 12-21-2011, 03:45 PM Thread Starter
What would a truck do with stage 2 injectors and a stock tune? and what would a truck do with stock injectors with stage 2 tuning?
post #10 of 10 Old 12-21-2011, 03:48 PM
duck fan's Avatar
You won't have much power either way. It will run rough. Slow to accelerate.
duck fan is offline
