Cant locate my PCM code?
Have a 2003 f250 7.3.
Im looking under my dash by the PCM, looking for a sticker somewhere. The wiring harness with the sticker and all and i dont see it anywhere. I see a faded sticker on one of the harnesses but doesn't look like the code. Ive been looking for like 15 minutes. Where is it? |
open the hood take a 10mm socket and undo the plug/wire harness...its the plug closest to the drivers side fender. under the dash take the plastic case holding the pcm in and slide it out. |
It's not under the dash. It's under the hood on the outside of the plug near the fender metal. I was able to see it with my kid's little makeup mirror and a flashlight. Smallish writing and it's hard to read backwards.
i gave you the steps to remove the pcm... and yes the pcm is under the dash. the mirror trick didnt work for me thats why i just said to pull it.. much easyier
Well i couldn't locate it anywhere in the hood, even with a mirror , and removing that little harness part. I couldn't find it.
Didn't remove the PCM fully but i basically said screw it. But i guess ill know where to look next time Already sent my chip order in and they gave me my code so. |
Check out this site. It may help you when you install the chip. This is also the location of the PCM Code. It is on the side of the thing that the 10mm bolt is on.
Welcome to guzzle's DP Tuner's Chip Installation Web Page |
I was reading around that it was under the hood, then it was by the PCM under the dash and couldn't locate anything. But that link is great! and perfect for helping me install the chip! By chance, does anyone know how far the switch will stretch, like how long the wires are? |
My PCM code was exactly as it should have been according to the year/model of my truck. The risk is that some previous owner may have swapped it with the PCM from another truck with a different code. |
my bad you were prolly wondering why i said that its just been one of them weeks
Anyways, the link that was posted will help me with installing that chip. |
