Transmission
I just got an 03 7.3 f250 4x4. I'm changing all the fluids on it and I was wondering how many quarts does the Trans take. It's an automatic 4 speed with over drive.
Thanks Jordan Sent from my Autoguide iPhone app |
Depending on if you are draining the torque converter. I will not quote the quarts as i do not know if you have a deeper pan or not. You can check with the part store they can give you a good estimate on what you will need.
Here is the best write up on tranny fluid flushing I have found: Changing ATF Fluid in a E4OD and 4R100 transmission .: Articles
On thanks guy that helps alot!
That is the best way other than using a machine which automatically refills the lost fluid as it is pumped out by the TC and not letting the machine pressurize anything.
Also, use DexIII. |
