alternator info needed - Ford Powerstroke Diesel Forum
post #1 of 9 Old 12-17-2011, 04:45 PM Thread Starter
Whats the plus and minus of more or less amperage on an alternator?
I need a new one. I see some are 110(stock) amp, others are 160 or 200 amps. Why would I want one over the other?
thx
2008 6.4 f250 lariat 4wd
melmount is offline
post #2 of 9 Old 12-17-2011, 04:59 PM
jesilvas's Avatar
Quoted: 3 Post(s)
It's low 100s IIRC. 105? Or 130. Heck idk.
Higher ones will handle more electrical equipment better. But don't go too high cause your wiring was designed for a certain amperage.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 9 Old 12-17-2011, 05:03 PM Thread Starter
I looked on eBay, they had 160 and even a high amp 200. Advance autos is advertised at 110. I guess that's enough. I am not running rad stereo equipment or anything. The high amp can damage wiring ?
melmount is offline
post #4 of 9 Old 12-17-2011, 05:07 PM
jesilvas's Avatar
Quoted: 3 Post(s)
I have the Duralast one. Lifetime warranty, and I know I'll be replacing it eventually
Just a regular stock one should be fine, even for a little bit of extra stuff.
Yea, if you try to shove too much electricity through a wire too small, then it will heat up and can melt.
Like if you have a pipe rated for 80PSI and you upgrade your pump to 120PSI, then you'll find the weak pipe really quick.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #5 of 9 Old 12-17-2011, 05:13 PM Thread Starter
I just read that higher amp won't hurt anything cause the alt will produce to what the draw is, high voltage alt,s can melt wires. My alternator,I just put in my wife's truck. Hers died. It produced 11.7 volts at idle. Mine was 14.3 at idle. She needs her truck tomorrow, so I need to get on in the morning.
melmount is offline
post #6 of 9 Old 12-17-2011, 05:21 PM
jesilvas's Avatar
Quoted: 3 Post(s)
Well both can too. Either way, if there's not a whole bunch of extras on it, I'd go with stock. Especially if it's a lifetime warranty.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #7 of 9 Old 12-18-2011, 02:50 PM
Fordman99's Avatar
My alt is on the way out and i do a lot of plowing and was wondering if i should just get it rewired to a high output? how much? and will it hurt anything the rest of the year?
E-99 f250 x-codes BD performance trans 35/12.5/15 mudders straight piped ......more to come
other car 2000 Lincoln ls v8----SOLD----
Fordman99 is offline
post #8 of 9 Old 12-18-2011, 04:28 PM
all the alternator does is recharge the battery... if you run high amperage items (winch, plow, stereo, extra lights, pull trailer with electric brakes) all those run off the battery and will drain it... the alternator then will sense the low voltage of the battery and turn up its output to recharge the battery... and as the battery gets charged the output will then lower itself to just what is needed to maintain the battery.
So if you have lots of draw on your batteries then get a bigger alternator.. of not the stock will be fine...
gijohn48 is offline
post #9 of 9 Old 12-19-2011, 05:26 AM
ridiculously_necessary's Avatar
fwiw, i believe the dbelectric alternatores are reated for amperage at a lower rpm for the diesels. the parts store alt i have on mine now its 130 amps at 6k rpm. 52 at idle. so at 2k rpm probably 80-90 amps? fwiw.
db's i think is rated at 1600 rpm. if you plow a lot i would look into one of those, even if its stock amperage, it will charge the batteries more quickly and allow for shorter depletion time, fewer and lower % discharge.
-Matt
Late 99 (2/99) Black F250, CC LB 4x4 Lariat 214k. All Stock for the moment...
1995 PSD, ext cab, one wheel wonder
, 297k miles, 30k on wvo. totaled 5/8/11 RIP This truck is for sale as a parts truck (Jason is about to receive forged rods, and drop kick his PMR's)
DB high torque starter
DIY 6637
Marinco Mod
DIY Electric fuel w/ wvo conversion
"A clean house is a sign of a mis-lead life."
ridiculously_necessary is offline
