Hey everybody, need a favor from those of you "in the know" about the reliable old 7.3L... I have a friend who's going to take a look at an early 99 ex cab, long box 250, 180k on the clock with a new factory reman tranny that's supposed to be still under warranty from ford. Bottom dollar of $9000 takes the truck. My questions are 1: What are the differences between a 99 and a 99.5 model, and 2: I've already checked out the thread about what to look for when buying a 99-03 truck, is there anything else he should be aware of that he might want to check out prior to purchasing this rig? TIA fellas!
Very little difference, main one that pops to mind is the turbo and pedestal is slightly different. Only problem with that is it is a little more difficult to upgrade to an aftermarket turbo. Also the air intake and box are slightly different which makes it easier to upgrade to a Baldwin PA2818 open element filter just by buying a 45 3” PVC fitting. Also there is not an air intake heater which is also a good thing. The Powerstroke badge is missing off the doors and there is a V8 badge on the front fenders. Make sure to look into the intake and check for dust signs and make sure the turbo impeller has nice square corners, a new engine will cost as much as the whole truck. I'll take an early 99 over a 03.5-07 any day.
Most of what was said it true. But... do not look at the door/fender tags. My early 99 has the door tags. Look at the build date (pre 12/8) should be an early 99. Also, the glow plug relay on top of the engine. Is there 1 or 2? If there is one relay, it is an early 99. I like the early 99 just as well as an 03. It has been very reliable and still runs very well... well enough that I will keep it for many more years. I'm not going to drop another 40k+ until I have to!
When you crank the engine up take the oil cap off and check to see how much blow by there is
Thanks for the help guys! Much appreciated.
Ditto on the blow-by.
I love the sound of an early '99. If I was in the market for a SD, I would prefer an early. |
