truck wont shut off - Ford Powerstroke Diesel Forum
post #1 of 30 Old 12-13-2011, 07:26 AM Thread Starter
ZachBoyer's Avatar
truck wont shut off
So i pull into work and turn my key off and take it out. The truck is still running.
My abs light and airbag light came on and all the gauges/radio shut off.
With the key in the ignition but off, I can still drive the truck, gears and throttle.
So I pulled the idm relay to Shut it off and my abs light and airbag light wouldn't go out.
The truck starts fine still, just won't Shut off or turn off.
So I Shut it down and unhooked my batteries.
Any ideas.? Could a faulty battery cause this issue because I have a battery that's bad and juat havnt replaced it yet...n
Thanks
2005 F250 6.0 King Ranch Crew Cab Short Bed 4X4
-MODS-
4" Turbo Back Straight Pipe
Sinister EGR Delete
Sinister Coolant Filter
Cat EC-1 Coolant
ZachBoyer is offline
post #2 of 30 Old 12-13-2011, 07:32 AM
Quoted: 5 Post(s)
i would say maybe your ignition has gone all wonky? dont think a bad batery would make it stay running.
Originally Posted by Ianstew
There is a difference in a government acting responsibly within their powers, and a government that just decides what their powers are and what responsibility means based on political whimsy.
ianstew is offline
post #3 of 30 Old 12-13-2011, 07:41 AM
rt_hawk's Avatar
Replace your ignition... Or whatever you call the thing you put your key in...my father in laws truck did the same thing. It also randomly engaged the starter, locked and unlocked the doors and the abs/radio stayed on too.
2008 F250 XLT CCSB- 90k, 5R110W, b&w hide-a-ball, DIY coolant filter, final charge, dieselsite boots, xrt pro, CAI, SGII, egt gauge, DIY egr cooler blocked/bypassed, viper alarm/ remote start, P/S filter
06 VW Jetta TDI- all options, 100k, stock for now...catching up on maintenance...
04 Triumph Thruxton, cr special carbs, TPUSA cams, MAS side-covers, Lossa stubby exhaust, pingel petc*ck, etc...
rt_hawk is offline
post #4 of 30 Old 12-13-2011, 09:30 AM
FordsNFishin's Avatar
Its called an ignition cylinder. To replace it, the ones ive had to do. You have to get a drill bit and drill out the center of it. Eventually it will come out. The new one you simply push in.
But to me it seems weird that all the gauges are shutting down, but not the engine....
Bass, Walleye, Catfishin, an Trout. I'm tellin yuh now, you best look out! You were safe on the lakes, while i was home wishin. But be on yur guard, cause im goin FISHIN!
"Thats what I love about these high schools girls, I get older, and they stay the same age."
-2001 F-250 SD Extended Cab, Long bed 7.3 Turbo'd/Built 4r100 Tranny/DIY Intake/PHP 6 setting chip/ 4'' straight piped exhaust w/ 6'' tip.
FordsNFishin is offline
post #5 of 30 Old 12-13-2011, 11:00 AM
Quoted: 157 Post(s)
Feedback Score: 3 reviews
WHOA! No,no,no, you don't have to drill anything....
Good pics on the removal ->
https://4656923915310766587-a-180274...attredirects=0
And yea, why would the rest of the truck shut-off I wonder? Also, if you can drive the truck with the key in the OFF position, why isn't the "wheel lock" engaged?
NoRalPh is offline
post #6 of 30 Old 12-13-2011, 11:54 AM
[QUOTE=NoRalPh;2801001]WHOA! No,no,no, you don't have to drill anything....
Thats just what you have to do on the other trucks i've done. But they are mainly older vehicles. Def dont quote me on these trucks as i have not done one.
That link you posted didnt work for me. Just curious what you do have to do to replace them in these?
post #7 of 30 Old 12-13-2011, 12:44 PM
Quoted: 157 Post(s)
The link didn't work? It's a redirect to a PDF (so, you would have to have Adobe) that was posted here by another member with lots of good info on his site.
https://sites.google.com/site/woodnt...nance-articles
I think you can click on "View" without having Adobe there..
Here's how it works though without the pics
Split the two halves of the column cover by removing the 3 long screws from underneath. From underneath, look up at the "barrel" the key cly rotates in and you should see a 1/4" hole, closer to the column, pointing down. Inside this hole is a sheet metal tab you need to depress. Rotate the key to the Run position, push the tab in with something, and draw it straight out.
Just be careful when reinstalling to have the key "indexed" to RUN and push it back in (the tab will click into that hole again)
NoRalPh is offline
post #8 of 30 Old 12-13-2011, 04:25 PM
On the older ones there is a little button you push in with a small screwdriver you never have to drill a ignition unless you do not have a key for the lock cylinder.
Please if you do not know what you are talking about do not offer your advise.
Please note I have taken locksmith classes so I know what I am talking about.
mgassel is offline
post #9 of 30 Old 12-13-2011, 04:34 PM Thread Starter
ZachBoyer's Avatar
OK I have not replaced the ignition switch, but have had some developments...
I got home and pulled into the driveway, shut my key off and the truck shut off...... AWESOME!!!!
So I lock the truck and all that is on is my automatic headlights..
As soon as my auto headlights go out, i hear my dinger all my gauge lights come on, headlights come back on, and my radio turns on.....
So i start testing... Get in cycle the key to on then off.. and everything is off except for my auto headlights, so i cycle my headlights to off, parklights, and on.
Everytime everything would turn on, except for if my auto headlights were on. then everything just came on when they shut off.....
I think this may be related to an earlier problem...
When i got into the truck and shut the door, then turned on the truck.. Sometimes my radio and windows would not work until i opened and shut my door.
Someone on here said that it was my GEM. The truck hasnt done this in awihle and it was intermittent.
Does anyone think this could be my GEM, i dont want to just go replacing a bunch of stuff that I dont have the money for if possible...
Thanks again!
-MODS-
Sinister EGR Delete
Cat EC-1 Coolant
post #10 of 30 Old 12-13-2011, 04:44 PM
belz's Avatar
Quoted: 70 Post(s)
Hmmm. I am under the impression that the GEM controls things like the radio delay and domelight and stuff but not the ignition or to keep the truck running. Is there any type of aftermarket remote starter in there? And you would not have to replace the key cylinder but rather the switch that it turns on the column.
Belz
CPA Director
belz is offline
