f series powerstroke to e series powerstroke - Ford Powerstroke Diesel Forum
Old 09-03-2007, 08:19 PM
what is the difference between a f series 7.3 and a e series 7.3? i have a 99 f 250 i blew the 99 f series stroke and replaced it with a 2000 E series powerstroke i put my turbo and waste gate on it but i'm not getting the power i had with the 99 are the injectors different or something?
how can i get the E series to runn like the 99 F series?
btw when we swapped the engines we used everything off my old engine on the E series engine so the only thing thats different is the engine its self
Old 09-03-2007, 08:27 PM
I think the E series are tuned down.
Old 09-04-2007, 03:35 PM
from the dealer
from what the dealer told me (ford dealer) the e series and the f series are the same motor just the e series has no waste gate and a different computer box
my truck has the wastegate and the f series computer box so i'm trying to figure out what the diff is besides the gate and the waste
Old 09-04-2007, 05:15 PM
Strokin' In Dixie-Land
Bump!
I'm curious, too
Old 09-04-2007, 05:44 PM
Almostdunfukinwidit
I think the E series engines had smaller injectors as well like the early 99's and obs trucks
Old 09-04-2007, 05:55 PM
and they have a short block their smalley the f series has a bigger long block
Old 09-04-2007, 06:14 PM
Is this a joke?
Old 09-04-2007, 06:18 PM
um
ok i know for a fact that there is no block size difference although the in jectors sounds more like it i was reall ycurious to know if the heads were different in other if to fix the problem i have would i just have to put f series injectors in it or woul di have to change the heads to.
thanks for the bump btw
Old 09-05-2007, 11:47 AM
No waste gate on the vans? I dunno, it's almost worth pulling the dog box off mine to check. I also would like to know of the diffrences, I need more power from the van for sure. Can you just put in the newer, or better, injectors? Swap the computer maybe?
Greg
Old 09-05-2007, 01:15 PM
vans
if you change the computer to an f series computer it helps a little bit but i'm like you if the injectors are the only difference then i'll go buy injectors
