Rough idle Fix - Ford Powerstroke Diesel Forum
Old 11-29-2011, 01:15 PM
Rough idle Fix
I have seen so many threads on a very frequently stated problem. Rough ldiling. So I figured to make a wright up to help people and stop the repetitive posting on the same issue. maybe an Admin can make it a sticky.
Hook up a scanner to find the exact problem, so that way you're not guessing. The AutoZone and common auto parts stores scanner will not read the codes on theses trucks. Get a good scanner to scan it, find your problem and fix it.
If you're having rough idle there are three things that you should replace first. Start with the CPS (Camshaft Positioning Sensor). It is located at the front of the engine between pulleys on the left side. Kind of a bitc* to get to. I believe it is a 10mm bolt if I remember right. Unplug it, remove it, bolt the new one in plug it back in. In my opinion you should get one from Ford or International. The ones you get from auto parts stores are not as good as one from a Ford or International dealership. $28. Also good thing to do is keep a spare CPS in your truck for back up In case you'd ever need it without having access To a store that sells them.
If this doesn't fix it try the ICP. (injector control pressure) it is located just to the right of the fuel bowl. It has a purple O-ring on it. Pull it out and see if there might be something stuck inside it. If there's nothing stuck in it (chances are there won't be, unless maybe you've done a resistor mod, which is not recommended) replace it. You can get them from Riff Raff diesel I believe, not sure on the price but I won't be anything expensive.
I you're still having this problem, next would be the IPR (injector pressure regulator). It is located to the right of the fuel bowl on the HPOP. (not positive on the location, correct me if I am wrong please). There is a wright up somewhere in how to remove it and clean it. I will find it an get back to y'all. Or you can buy a new one from Riff Raff for about $170.
If none of these have fixed the issue, then you've got more serious problems. Way late on oil change, malfunctioned HPOP, bad fuel, bad fuel leak, diesel in your oil. Chances are that if you replace the ones I stated one f them will fix the issue, but there's always the odd problem.
These are the most common problems of bad idling and dying. But like I stated above hook up a scanner to find te exact problem, that way you're not throwing parts at it.
-Austin Herd
PM me with and questions or feedback on something I should change about the post
Old 11-29-2011, 03:18 PM
So, let me understand this.......
You're suggesting people who are having a problem with their truck should first open their wallet and start throwing parts at it to see if they can "get lucky" -really????
No, No, No,,, that's not a good solution at all
Look at what your total would be with these 3 items alone $130 ICP (I looked @ RR) $30 CPS & $170 IPR = $330.00! Did you know you'd be a mere $20 away from buying the Best diagnostic too you can get for our trucks (AE w/Enhanced Ford package) and that would enable you to figure-out which one of those parts was actually Bad in the first place
Old 11-30-2011, 05:28 AM
Dumb question but what is a "AE/w enhanced ford package"? Because i have had several things changed and mine still idles kinda crappy or at least to me it does
Old 11-30-2011, 05:47 AM
Good point man. I was stating the most common issues, but I stand corrected. Hook up a scanner and find your exact problem before you start throwing parts at it. Thanks for the input
Old 11-30-2011, 06:18 AM
The Autoenginuity -> OE-Level Coverage (Enhanced Interfaces)
This sucker does 90% of what the techs at the dealership use to diagnose your problem what you bring it to them
Nothing else, for even twice the money, comes close. Google it, should be @ $350 delivered, AE sells at a discount on eBay too.
I know how tempting it is, been-there-done-that ya figure "it's probably this, let me try a new one..." BUT after a while (even My thick head) learns to step back and take it one step at a time to diagnose
