Tire Question - Ford Powerstroke Diesel Forum
post #1 of 7 Old 11-28-2011, 06:54 PM Thread Starter
Tire Question
Okay after looking through 10 pages of search results and not finding an answer I am going to ask my question.
I have a e99 f250 with 6000lb front springs. Will a 305/70/16 fit without rubbing? I know that I will have to go to a 8in wide rim to fit the tire so the only question is the rubbing.
If there is rubbing is it just on the fender well or is it on the leaf?
Thanks!
schroederness is offline
post #2 of 7 Old 11-28-2011, 09:47 PM
Zaairman's Avatar
Quoted: 12 Post(s)
A 285/75/16 will fit on stock rims no problem. A 305/70/16 shouldn't rub, but it also depends on the back spacing of the rims you get.
Zach
2000/2006ish Ford F-250 Larryette 7.3 Powerstroke 4x4
5" Sewer Pipe Exhaust
, DIY 6637 Intake, Wicked Wheel'd, De-foiled, Missing EBPV, Edge Juice with Attitude, Few leaves added here and there, 35" BFGs, 16x10 Eagle Alloys, Alpine W200
SLAPS Member #153
Zaairman is offline
post #3 of 7 Old 11-29-2011, 05:51 AM Thread Starter
So if I got a rim with 0 backspacing like stock then I would be fine or do I need to get something different?
post #4 of 7 Old 11-29-2011, 09:26 AM
I have a 2wd with 305/70/16's on 10 inch rims. I get some minor rubbing on the back side of the left inner fender well when making a sharp right turn. Not sure how a 4wd would do.
late 99' F350, Crew cab, SRW, 4guage pillar pod, combo driving/fog lights, 55w backup lights, drivers side battery isolation mod,6637 intake
coot1 is offline
post #5 of 7 Old 11-29-2011, 10:25 AM
i ran 315's on stock with a levelin kit and the only thing it rubbed was the leaf spring
bruce51d is offline
post #6 of 7 Old 11-29-2011, 02:14 PM
Toms01PSD's Avatar
Quoted: 64 Post(s)
People have run 305/70R16's on stock wheels. I don't know about rubbing issues but it's been done.
Tom
2001 F250 7.3 auto 4x4 Lariat CCSB
6637 intake
4" MBRP exhaust
PHP tunes
Foil delete
EBPV delete
ISSPRO Boost, Pyro, and Trans Gauges
Strictly Diesel Pre-Pump Filter/In-Tank Kit
Strictly Diesel Regulated Return and Fuel Bowl Delete
High Flow Banjo Bolts
Nitto AT's 305/70R16
2009 Pontiac G8 GT
Intake, Exhaust, Tune
Camaro 20's, Camaro SS Brembo's
1997 VDub Passat GLX VR6
Toms01PSD is offline
post #7 of 7 Old 11-29-2011, 09:46 PM Thread Starter
Would negative backspacing help with the rubbing issue? I dont really understand the negative positive backspacing.
