Trouble with Mirrors - Ford Powerstroke Diesel Forum
post #1 of 8 Old 11-28-2011, 05:42 PM Thread Starter
formulaj's Avatar
I have Towing Mirrors on my 02 F250. When using the controls on it the mirror moves but not in the right directions what could be the cause of this?
-2002 F-250 Crew Cab Lariat
-F5 DP-Tuner
-S&B Intake
-4" Turbo Back Magnaflow
-1997 Pontiac Firebird Formula
-Lots of money wasted in mods
-2004 Ski Doo Rev 800 Modd
formulaj is offline
post #2 of 8 Old 11-28-2011, 05:57 PM
Bigdock's Avatar
I have the same year model my mirrors go down but they won't go back up I have to manually push it up probably the same problem hope some can help us out
Bigdock is offline
post #3 of 8 Old 11-28-2011, 06:00 PM
Eric's Avatar
Feedback Score: 6 reviews
I would assume that it's the switch. My old mirrors did that and my 08 mirrors do the same thing. I've just never cared enough to fix it
Early 99 F250 with a bunch of extra junk...
Eric is offline
post #4 of 8 Old 11-28-2011, 07:42 PM
Quoted: 14 Post(s)
Yep. Mine would both move to the right and down. Bought a new switch from rockauto.com and the problem was fixed. It's only $13 or so plus shipping.
ttyR2 is offline
post #5 of 8 Old 11-29-2011, 06:58 AM Thread Starter
formulaj's Avatar
Thanks, I just oredered mine called the dealer they wanted $34 got it shipped $13.55 form rockauto.com
-F5 DP-Tuner
-S&B Intake
formulaj is offline
post #6 of 8 Old 11-29-2011, 08:04 AM
jacobm24's Avatar
I had the same problem and switched out the switch and it fixed everything
2000 f250 7.3 w/ 103k miles
4" MBRP turbo back exhaust
DIY Intake with AFE big boost filter
Autometer Cobalt gauges (trans, boost,pyro)
PHP Phoenix stock, 40ht,80dd,120race
Wicked Wheel
Harpoon Mod
203* thermostat
Dieselsite coolant filter
Dieselsite IC Boots
Fightin' Texas Aggie Class of 2013!
Petroleum Engineering
jacobm24 is offline
post #7 of 8 Old 12-01-2011, 02:09 PM Thread Starter
formulaj's Avatar
I ordered the switch and it helped a little the mirrors work better but still not the way they should. Any other ideas what it could be?
-F5 DP-Tuner
-S&B Intake
formulaj is offline
post #8 of 8 Old 12-01-2011, 06:02 PM
Govy Magnet
zambonimaxx's Avatar
You don't always have to pull and rpelace the switch a lot of the time its simply the contacts are dirty. I remember my F150 had the same issue, pulled the switch apart and cleaned the contacts it was the McGuires that I was cleaning ythe rest of the door with built up on them.
~Phil
"Initial Success or Total Failure"
2002 F250 SC SB 4x4 7.3ltr
~leveling kit~35/12.5~B&W~MBRP 5"~4 Pod Gauge Pillar ~TW 6 POS~Mag-Hytec~LineX]~KC Long Range (Front)~KC Wide Beam (Rear)~Cobra CB~WW~CFM+~EBPV Delete ~6kHID's~OUO Blocks~3/4" Ubolts~OUO Adjust ladder bars~Full RR system w/ Fuel Bowl Delete~ CCV~BTS TRANNY
~ 6.0 Tranny Cooler ~ BHOF/Coolant Filter/ Fltr Mags
2012 Harley Davidson FXDB
2010 Jetta TDI traded for...
2012 Chrysler Town & Country
zambonimaxx is offline
