Parts to change OBS 7.3 to SD?
I have an OBS 7.3 that i am putting in an 02 SD to replace the blown PMR engine that was in it. My question is exactly what do i need to change to make it a completely 02 engine? Obviously the accessories and brackets, turbo, pedestal, injectors, HPOP, HPO res, UVCH, wire harness and plenums. What else? Front cover? Water pump? Exhaust manifolds? Oil cooler? If someone could, give me a list of every part that is different between OBS and SD 7.3s. I'm already changing out the flex plate for a flywheel since the engine came out of an auto truck and its goin in a zf6 SD.
Eh at least people somewhere else actually answer your posts jake. *cough*
Get 'er done. |
Hence the reason i post on multiple forums
I know ill get an answer, and from various people too.
Just everything you named off. Everything else is the same. Unless you wanna put the PMR's in anyway
![]() Edit forgot about the front cover Last edited by Dave; 11-26-2011 at 04:49 AM. |
i know for sure wiring harnes injectors pedestal turbo....do you still have the 02 motor if so it should have everythimg you need on it already, I do have the pedestal and spider intake off a 03 id sell if that may help
I have everything from the 02 motor. It just had a hole in the block when i got it.
