starts with key in acc position
Early 99 psd is acting up while on the road. Limited access with phone. Help much aprreciated.
Truck goes into park but doesn't feel right. Can hear a whine an well like something isn't fully engaged. Then truck turns over and starts as soon as key is turned on. Its only in the acc position. Im not getting to the start position. Works for now but scared to stop and let it cool off....don't think it'd start if glow plugs needed to energize |
Anybody know if the neutral safety switch could cause this
anyone know if the ignition switch would cause this? And/or what to look for
I don't understand your symptoms though.....
You put the key IN, as you go to start it you only get to the RUN position? Before the "spring loaded" START position? OR are you saying you have to rotate the key BACKWARDS to the ACC position OR is there an ACC position BEFORE the RUN position? THEN what happens? (which ever position we're talking about...) the starter engages? BUT, Then, what do you do to turn the starter OFF so it doesn't crank into the running flywheel? And no, the NSSW isn't involved. I would wonder if the starter relay (above the pass wheel well) is stuck but, then, the starter would be turning all the time... Make things clearer as to exactly what's happening... |
Sorry
Put key in turn forward only get to run position and it starts cranking. Truck started ok but was already hot. Starter seems to kick off and it runs ok other than the odd starting. Doesnt seem to get all the way into park though. Can hear a humming sound like something isn't fully engaged or unengaged. Truck is in park when in park position but just doesn't feel right if that makes sense |
OK, well first I'm not sure, if it's in the same position it cranks/stops-cranking/& runs in, How that works. Does the Ign Sw "feel" normal? That is, does it do the "Spring Back" from the, normal, starting position properly? Can you even go there?
See, if there was just One position I would think you'd hear the starter running. So, maybe what's happening is that the Run and Start contacts in the switch aren't right (like it was bad) and you're not really aware of the subtle position change? I just can't make sense of it otherwise How would the starter be disengaging.....As for the PRNDL, if the pawl in the trans engages (so it's not rolling) and Neutral is in "N" then, I'm not sure how it can be related. What do you mean by a "humming or whining"? Where is That coming from? The Trans? The Dash area? Under the hood? I'm Sorry I'm having such a problem relating to your troubles, I can't envision any of it!
How many miles?
Sounds like the ign switch and the shift linkage are worn out. There is a thread on here talking about tightening up the shift linkage. I cant search on my phone right and also would like that info! |
Both issues started at the same time so I believe them to be related but....let's start with the starting.
Put key in ignition turn forward to on....as you would to energize glow plugs Truck starts turning over as soon as key is moved. Never gets to the spring loaded start position. Truck wil drive normal. Hope this helps its hard to explain and really hard to search. Truck has 350000 on it. Would sometimes not engage starter and I would have to run shift lever from park to drive and back. |
yeah it sounds like you need a new ignition switch. Very easy to replace. Just gotta go to your ford store and order one or maybe just pick one up and hopefully they can re key it for your exact ford key you have now. It took me maybe 3 mins to install my new ign switch after i had it at my place
The key switch still has the "spring" in it. Just startsdoesn't cranking before it gets to that point. Do you think its the key part of the ignition or the box farther down on the column?
