Scan revealed laundry list of codes!
I am thinking my service engine soon light must be disconnected because I never had it come on and yet all these codes came up?
When I picked up my truck from the transmission shop he gave me a list of codes that came up on his intial scan. I have googled them, researched them on here and I feel I have somewhat of a handle on them. P0381 glow plug circuit? module may be bad? P0603 power control module,Would programming probably set this off? P1134 bank 1 fuel rich Would this be programming as well? P0541 manifold heater? This was disabled when I did air filter mod C1226 brake lamp output... must have a short somewhere, maybe trailer connection, everything else seems to work B1318 battery low voltage, just put new batteries, maybe testing drained it some or testing was done before it built back up after cranking? B1450 wiper/washer circuit, all works fine..... B1371 illuminated entry relay circuit, is this the sensor/switch that makes the dome light come on, this fuse tends to work loose... ![]() I have several airbag related codes, makes me wonder if the airbag is even in there... ![]() B1869 airbag circuit open B1884 PAD warning circuit inoperative B1891 airbag warning, short to battery B1892 airbag circuit failure What do y'all think? Everyone on here has been just awesome. I value your input tremendously. Thanks and Happy Thanksgiving! Get your feast on!!!
Have you tuned your truck? I've had similar issues where all sorts of codes will come up when there is a problem with the voltage. I had B1318 and a bunch of other codes come up, and I had a bad cell in one of my batteries. Replaced both and the check engine line went off. However, it just came back on (a couple days later) and it's throwing the B1318 along with a few other codes, and I've noticed that the truck is getting jumpy and will rev itself up. I'm thinking it's getting too much voltage (As I've got dual alternators, along with two new 850CCA batteries) so I will update you when I know something, and if you've figured anything out please let me know as well.
To be honest I haven't done anything about those codes. I have been driving almost daily since without any problems including multiple 150 mile trips to Lexington from here. Hopefully, it will continue that way. I do have a Super Chips programmer, it came with the truck and I have used it once or twice but I don't remember what setting I even have it on. I remember that it didn't seem to make a difference what settings I picked, it ran/drove/pulled the same.
I lied, I just remembered my windshield washer pump is going. It only sprays a couple inches, just hits the bottom of the glass. It could be a clog or something, but I'm thinking pump. I use rainex washer fluid and its been in the 50's and 60's so I know its not ice or anything like that clogging the lines up.
clear codes and drive for a while. check again. Most should be gone
Thats what I would do. With that many codes its imposible to track them all down. See what comes back after clearing them.
