ZF6 Swap Question - Ford Powerstroke Diesel Forum
post #1 of 43 Old 11-21-2011, 07:04 PM Thread Starter
PMR = JUNK
Jake's Avatar
Quoted: 5 Post(s)
ZF6 Swap Question
A buddy of mine wants to put a zf6 in his sd. He found a good deal on everything needed to do the swap. The problem is that it is a 2wd trans. What is needed to make a 2wd trans work on a 4x4 truck?
BPS President
2000 F-250, forged rods, 38r turbo, BTS trans, hutch mod, TW tuning and Bad Night Special 50 horse Caterpillar injectors
Originally Posted by alberta 7.3 View Post
Yeah, I'd probably feel a bit drained after firing twice in rapid succession.
Jake is offline
post #2 of 43 Old 11-21-2011, 08:12 PM
hammerstroker's Avatar
anyone? if this will work im buying it. any help would be awsome
"BIG RIG" auto to zf6 swap 00 f-350 cclb dually,4in rough country lift, 6637, 7in mitre stacks, wicked wheel, foil delete,live tuned from bill at php,triple pod autometer gauges,315/75r16 kelly tsr's, 05 front end conversion, 2in spacers for rear,stage one swamps 175cc single shots,boost fooler, kennys dual disk clutch.
hammerstroker is offline
post #3 of 43 Old 11-21-2011, 08:47 PM
spool up that turbo!!
hollister25073's Avatar
You can use your transfer case from your auto but you have to change the input in the transfer case cause I believe the ZF has a smaller output shaft but I see if you can pick up a cheap case at a junk yard first might be easier
01 f250 4dr LB 6spd
s&b, cfm+
4in straight pipe
DP tuner
boost pyro and engine oil temp
AIH delete, hpx, frx
05 harleys 8000k's
billet grille and painted shell
17"welds and 35-12.5's toyo mt's
cab lights
southbend con ofe waiting to go in
fresh 7.3 from reviva
SOLD
1995 f150 302 5spd 35's sad sad day
hollister25073 is offline
post #4 of 43 Old 11-21-2011, 09:05 PM Thread Starter
PMR = JUNK
Jake's Avatar
Quoted: 5 Post(s)
I knew about the input shaft needing changed on the tcase, but what about the actual transmission? Can we even use it or is the case different on a 2wd?
BPS President
Jake is offline
post #5 of 43 Old 11-21-2011, 09:05 PM
The case is the same as long as its a 7.3
01 f250 4dr LB 6spd
s&b, cfm+
4in straight pipe
DP tuner
05 harleys 8000k's
cab lights
SOLD
post #6 of 43 Old 11-21-2011, 09:28 PM Thread Starter
PMR = JUNK
Jake's Avatar
Quoted: 5 Post(s)
So if we got a new tailhousing and switched the input on the tcase it would work then?
BPS President
Jake is offline
post #7 of 43 Old 11-21-2011, 09:51 PM
I believe so
01 f250 4dr LB 6spd
s&b, cfm+
4in straight pipe
DP tuner
05 harleys 8000k's
cab lights
SOLD
post #8 of 43 Old 11-21-2011, 09:57 PM Thread Starter
PMR = JUNK
Jake's Avatar
Quoted: 5 Post(s)
You THINK so? Kinda important info.
BPS President
Jake is offline
post #9 of 43 Old 11-21-2011, 10:20 PM
All the swaps I've been involved in have been full ZF plus tcase swaps lol sorry I can't be much help
01 f250 4dr LB 6spd
s&b, cfm+
4in straight pipe
DP tuner
05 harleys 8000k's
cab lights
SOLD
post #10 of 43 Old 11-21-2011, 11:59 PM
Winning DUHHH
Young-SC-Owner's Avatar
Quoted: 8 Post(s)
Nvm, I misread.....bump
99.5 F-350 SRW Short Bed, Ex Cab.
6637
Wicked Wheel'd,
Southbend
Autometer - Boost, Pyro
TW 6 Pos Chip
Water/Meth Inj
Diamond Eye 4" TB
7 year Veteran with SBFD
Airframe and Powerplant Mechanic
Head Marine Technician
Dont Tread on Me
Young-SC-Owner is offline
