5.4 Gasser conversion to 7.3 Diesel - Ford Powerstroke Diesel Forum
Old 11-20-2011, 05:52 PM
i got a line on a cheap 2001 f250 with a blown gas V-8.
Is it economically feasible to take a gasser and drop in a 7.3?
The 7.3's are becoming harder and harder to find, so I was thinking maybe I could maybe drop in a 7.3.
Any help or insight would be appreciated.
Old 11-20-2011, 06:22 PM
Physically Id think it would fit just fine. Wiring however might be an entirely different issue.
Old 11-20-2011, 07:40 PM
No, not at all.
Old 11-21-2011, 05:33 AM
Well that pretty much rained on my parade.
Old 11-21-2011, 05:35 AM
Feedback Score: 7 reviews
Send a message via AIM to dereku
not without a donor vehicle. So if you can find a rollover or completely totaled one then it could be close. But its better off to fix and sell the v8 and buy a 7.3
Old 11-21-2011, 07:24 AM
Send a message via AIM to rufushusky
"economically" and "diesel" are kinda contradictory terms, right?
Seriously, not it would be MUCH cheaper IMHO to just buy a 7.3 power truck
^^ another option is a cummins swap...wiring won't get any easier than a VE or p-pumped 12V...still not cheap. Your spending at least $5-6k....at least!
Old 11-21-2011, 08:49 AM
It would be very simple. Get a donor truck, and it's all plug and play. As the truck was offered with a 7.3 as an option, it is a very simple ordeal to convert it.
Old 12-02-2011, 08:48 PM
I currently have a 99 F250 SD with the 5.4L and manual 5 speed. I have found a 7.3L, rearend wrecked, 97 F350 also with a 5 speed. My question is will the 97 7.3 mount into my truck? the 7.3 currently will run but has been totaled and my motor has a bent rod and blown plug. I know i would have to take the wiring harness out of the 97 and put into my 99 but with the body changes i didn't know if there would be any complications. any help or suggestions would be greatly appreciated!
Old 12-02-2011, 08:53 PM
You would be best off getting a superduty donor, as it would simplify wiring significantly. You will have to source a lot of parts should you decide to use the OBS truck that are superduty specific-pedals, hydroboost, etc. The motor will physically fit if you use SD mounts (from a 7.3), as will the trans, but as the SD had the 6speed, you won't get an off the shelf crossmember to fit. There will be a lot of work required to make the OBS drivetrain function in the SD.
