37 12.50 16.5 hummer tires on f250?????? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 11-13-2011, 07:34 AM Thread Starter
150guy's Avatar
hey i have been looking at running these goodyear military take off tires i can get for cheap only problem is idk if i have enough lift i have a 6in rouch country but i have 33s and there dosent seem to be a whole lot more room maby 3in from the side of the tire till i start hit my fender (the truck body)
and i dont mind triming the bumper but i dont want to touch my actual body
should these be able to fit? the back looks like no problem
is there anyone on here running the military tires with a 6in lift ??
how much room for flex do you have?
can you put up a good side shot of your truck
my friend said that going from a 33 to a 37 only adds 2in on each side of the rim is that ture?
thanks in advance!
2001 7.3 f250
6in Rough Country Lift
DIY Intake
Straight pipe
Coolant Filter
AIH delete
4.6k Mod wired to switch
293k and counting
yea go ROTELLA!
150guy is offline
post #2 of 10 Old 11-13-2011, 07:44 AM
atvrider93's Avatar
Quoted: 8 Post(s)
you have 33s wit ha 6in lift? I'm not sure about a superduty but with a tiny bit more bumper trimming I could fit them stock height.
ya, your truck will be 2" taller because 37" is the diameter of the tire so half that is the radius
1996 F350 4x4 CCLB-- I'll miss her
1996 F350 4X4 RCLB zf5 213K
6637
OBA w/horn
DE 5"
PHP tunes
Mud Country 315/75/16
2008 Wr250X
Originally Posted by belz View Post
There u go Tom. John may not be sexy, but he can tutor you, lol.
atvrider93 is offline
post #3 of 10 Old 11-13-2011, 08:22 AM Thread Starter
150guy's Avatar
your fitting 36s stock wow i guess you can stuff some big tires with the obs trucks i just dont want to buy the tires if they wont end up fitting or being un useable offroad =\
2001 7.3 f250
DIY Intake
Straight pipe
Coolant Filter
AIH delete
293k and counting
yea go ROTELLA!
150guy is offline
post #4 of 10 Old 11-13-2011, 08:29 AM
atvrider93's Avatar
Quoted: 8 Post(s)
I dont know how much articulation you'll get but you should be able to fit them fine with a little bumper trim
6637
OBA w/horn
DE 5"
PHP tunes
2008 Wr250X
post #5 of 10 Old 11-14-2011, 10:59 AM
I run them on my 97 F150 on 2002 D60/10.5" with very minor trimming. My dad runs 37"s on his 2000 PSD with a levelling kit.
My dads truck with leveling kit. 37" BFG KM2's
Heres the Military radials.
built and blueprinted Lightning powerplant with p&p heads, race built 4r70w by Darrin @
avoid
, junk import motors.<hr>
Klitch is offline
post #6 of 10 Old 11-15-2011, 08:16 PM Thread Starter
150guy's Avatar
cool so i should be goodthx
2001 7.3 f250
DIY Intake
Straight pipe
Coolant Filter
AIH delete
293k and counting
yea go ROTELLA!
150guy is offline
post #7 of 10 Old 11-16-2011, 02:05 AM
93stang's Avatar
With those on a 6" lift you will rub the inner fender well if the wheel is turned and hit a bump. I also had to trim the bumper just slightly to clear.
2005 F350 Crew Cab Lariat 4x4 Dually.. My new Fat Bottom!!! SCT SF3, blue spring upgrade and Straight Piped! Studded and deleted, custom tuning hopefully coming! 22.5 American Force Independance wheels!
93stang is offline
post #8 of 10 Old 11-16-2011, 07:43 AM Thread Starter
150guy's Avatar
hit the inner fender well =[ thats no good so i would have to becarefull offroad?
how bad do yours hit on your 6.5in lift?
2001 7.3 f250
DIY Intake
Straight pipe
Coolant Filter
AIH delete
293k and counting
yea go ROTELLA!
150guy is offline
post #9 of 10 Old 11-16-2011, 10:11 AM
we remedied the inner fender by drilling a new hole about 3/4" away from the old one for the plastic "rivet"
avoid
Klitch is offline
post #10 of 10 Old 11-16-2011, 11:30 AM Thread Starter
150guy's Avatar
cool yea so just some redesigning of the fender skirt and maby slight triming and ill be good to go thanks guys for all the help and Klitch love that f150
2001 7.3 f250
DIY Intake
Straight pipe
Coolant Filter
AIH delete
293k and counting
yea go ROTELLA!
150guy is offline
