Help! Injector install gone wrong - Ford Powerstroke Diesel Forum
Old 11-12-2011, 10:29 PM
spool up that turbo!!
Started doing a simple injector replacement on my buddies 7.3 excursion and did the passenger bank tonight got it all done and now the engine acted like its hydro locked so I bared the engine over and it moves fine and now when I go to start it it makes a horrible racket I hope the starter just took a dump from it hitting a stop but I hope someone has an idea what it may be I've done 4 full injector replacements on 7.3's and never had this happen and never drained the rails prior to removing injectors
Old 11-12-2011, 10:39 PM
Send a message via AIM to helsel_182 Send a message via Skype™ to helsel_182
stupid question but are the injectors from a reliable source and with all new gaskets....
Old 11-12-2011, 10:43 PM
Yeah the are straight from alliance I bought my injectors through the same dealer as did the other sets
Old 11-12-2011, 10:53 PM
is it still acting like it is hydrolocked or did it only do it at first
Old 11-13-2011, 06:29 AM
Now it will crank it just makes a horrible grinding sound so I'm hoping it's just a starter
Old 11-13-2011, 02:33 PM
Top tab on the starter was sheared off after a new starter and some priming cranks she fired thank god
Old 11-13-2011, 06:45 PM
Drained the rail on the drivers side install and is acting hydro locked again
Old 11-13-2011, 07:48 PM
Feedback Score: 7 reviews
You need to pull all the glowplugs AFTER installing new injectors and spin it over until there is no more oil and fuel in the cylinders (it makes a mess,but spin it over with the starter until nothing is blowing out the GP holes). It's acting hydrolocked because it is hydrolocked. Be careful, you can and will bend a rod if it starts with liquid in the cylinders.
Old 11-13-2011, 08:31 PM
I spun it over by hand with the injectors out
Old 11-13-2011, 08:35 PM
well that isn't even CLOSE to good enough. You NEED to spin it over WITH THE STARTER with the injectors installed, but the glow plugs out. I guarentee that if you remove the GP's, unplug the UVCH, and spin it over with the starter, you will get a geyser out of the cylinders. Spinning it over by hand with the injectors out will not get enough of the oil and fuel out of the cylinders.
