Need to warm up truck or not?!? - Ford Powerstroke Diesel Forum
post #1 of 19 Old 11-10-2011, 04:33 PM Thread Starter
ScottyP5947's Avatar
Quoted: 2 Post(s)
Ok, I have surely heard a lot of folks who insist that we must warm up these trucks before rolling them down the road. I have owned a few diesels and many gassers, never had a problem with this technique. Back in Buffalo, I warmed up the car because I wanted to be warm not because the car needed it.
I have always been of the mindset of oil pressure = good to go. I let it idle for 30 seconds or so and I am off, no matter the temp. I don't rip on it, I just drive a touch slow the first .5 miles then normal driving.
I wish there was a retrofit kit or something for instant cabin heat like the new Powerstrokes have.
What are your thoughts?
Scott
2000 XLT F-250 7.3 Crew Cab Auto w/Transgo shift kit
Zoodad
4" MBRP turbo back exhaust w/muffler
PHP TS chip - 65 tow/80DD/120 race
Stancor relay
Caterpillar ELC coolant
Broken-into door lock mod
6637 filter
285/75/16 Hankook ATM's
2" Rough Country add a leafs all around
In the Driveway:
2000
, chipped! (For the wife)
1995 Ford Mustang 3.8 (
2012 Dodge CCSB 2500 w/Hemi
ScottyP5947 is offline
post #2 of 19 Old 11-10-2011, 06:04 PM
JEL
I don't warm up, just do like you and let it idle for about 30 second and take it easy until it's all the way up to temp. If I get a PHP I will get a high idle position, but I wouldn't let it just warm up at standard idle for very long.
JEL is offline
post #3 of 19 Old 11-10-2011, 09:54 PM
Agreed.. I think 5 mins max(in extreme colds) would be the longest, even then its not building heat in that temp, unless you have a high idle tune..
Dietoremain is offline
post #4 of 19 Old 11-11-2011, 03:14 AM
mxfever090's Avatar
I plug mine in on a timer below 30 that comes on 3 hours before I leave. Then I start it, scrape the windows and leave. It gets driven like I'm 97 years old until the temp comes up a little bit though. Don't really know if this is really necessary I just don't like the sounds of ball bearings getting launched around under the hood till she's warmed up.
Jason
O.T.F.D. Volunteer 19
Great White - 2003 7.3l F-250 4x4 CCSB -102,000 miles and tickin
DIY intake - 4" Straight pipe - HPX - CAT ELC - 203 t stat - billet t stat housing - coolant filter - dual alt radiator hose - 12V Air compressor - 5 gallon air tank - Air line quick connects - AIR HORNS!
Hers: 2013 VW Jetta TDI
mxfever090 is offline
post #5 of 19 Old 11-11-2011, 05:10 AM
Quoted: 17 Post(s)
Send a message via AIM to rufushusky
I do about the same, it might get a few extra seconds if I need to scrap the windows but idling away for 20 minutes isn't doing your engine any favors. If you want heat in the cab quicker I would plug the truck into the timer and have the timer set to turn on 3 hours before you leave.
2002 F-350 4X4 ECLB 7.3 4R100 6637 filter w/ RiffRaff cover, 08 diff cover, 203* T-stat, HPX, Stancor Relay, 6.0 trans cooler, Zone leveling kit, 8'6" Western Ultramount
Sold: 04.5 Dodge Ram 2500 5.9 CTD, Reg Cab, 48re
rufushusky is offline
post #6 of 19 Old 11-11-2011, 08:23 AM
Govy Magnet
zambonimaxx's Avatar
I have it plugged in under 35, as stated above also with a timer and 3 hours before start. I start it, hit the high idle, go inside and grab the existing things I may need, and fill up my coffee cup and water bottle, then leave. I keep the RPM's under 2250 until my temp gauge is in the nominal range. I am unsure if the temp gauge is an idiot light like the tranny gauge though, when I do a fuel pressure gauge I am getting a true engine coolant temp.
~Phil
"Initial Success or Total Failure"
2002 F250 SC SB 4x4 7.3ltr
~leveling kit~35/12.5~B&W~MBRP 5"~4 Pod Gauge Pillar ~TW 6 POS~Mag-Hytec~LineX]~KC Long Range (Front)~KC Wide Beam (Rear)~Cobra CB~WW~CFM+~EBPV Delete ~6kHID's~OUO Blocks~3/4" Ubolts~OUO Adjust ladder bars~Full RR system w/ Fuel Bowl Delete~ CCV~BTS TRANNY
~ 6.0 Tranny Cooler ~ BHOF/Coolant Filter/ Fltr Mags
2012 Harley Davidson FXDB
2010 Jetta TDI traded for...
2012 Chrysler Town & Country
zambonimaxx is offline
post #7 of 19 Old 11-11-2011, 08:26 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Heres what I do.
I go out start the truck. Run back in quick grab a soda and give the dog a treat. Then I go.
Once it gets down below 15 degrees I plug the truck in on a timer set to come on 3 hours before I leave. The rest of the routine is the same
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #8 of 19 Old 11-11-2011, 09:28 AM
Zaairman's Avatar
Quoted: 12 Post(s)
I'd at least give it long enough for the glow plugs to turn off, which is about 90 seconds. It really depends on how cold it is and if it's been plugged in. If it hasn't been plugged in, I'll let it idle for a few mins for the smoke to clear up.
Zach
2000/2006ish Ford F-250 Larryette 7.3 Powerstroke 4x4
5" Sewer Pipe Exhaust
, DIY 6637 Intake, Wicked Wheel'd, De-foiled, Missing EBPV, Edge Juice with Attitude, Few leaves added here and there, 35" BFGs, 16x10 Eagle Alloys, Alpine W200
SLAPS Member #153
Zaairman is offline
post #9 of 19 Old 11-11-2011, 10:26 AM
In the summer I don't warm mine up very long, maybe a few mins and i'm off. But in the winter I plug in and let her idle a good 15 mins or so before I even hop in it(remote start). But I live in AK so it gets a little cold and I hate cold trucks. Heated garages FTW!
Early 99 F250 4x4 CCSB w/ LATE 99 engine
- TW Chip, 5" straight exhaust, DIY intake w/ Amsoil 4095 filter, Gauges, ITP Pre pump filter and tank mod, Riffraff IC boots, AIH delete, EBPV delete, Foil delete, 3" lift on 35" BFG KM2, , custom rear bumper, Lightforce 170 lights
Blasterak is offline
post #10 of 19 Old 11-11-2011, 11:25 AM
Galaxie's Avatar
Similar to Dave. I fire her up. Got to the mail box and get my AM paper. Set the radio and go. So its about 2 minutes.
If it is really cold she is plugged in. This morning it was 30* not plugged in. By the 2 minute mark she was at 65*. I limped down the road for the first few miles.
Colin
59-68Galaxies, Fairlanes
54 Ford Skyliner Glass Top
60 Country Sedan Wagon
87/93 5.0s 347
Buy/Sell/Trade/Service 40s50s60s cars!
06 F350 Dark Stone XLT FX4
SCTX3 Custom Tunes
ARP Head Studs
EGR Cooler gone
MBRP Stright Pipe
Edge Insight
20" Harleys 35" AT2
2011 Tailgate
Eaton TrueTrac
2" Leveling
Black Windows/lights
Blue Spring
03 Turbo
Galaxie is offline
